Thread Number: 3318
What washer is best? |
Post# 83595 , Reply# 4   9/17/2005 at 10:40 (6,796 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 83946 , Reply# 5   9/19/2005 at 13:33 (6,794 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 83952 , Reply# 6   9/19/2005 at 14:15 (6,794 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 83992 , Reply# 7   9/19/2005 at 19:01 (6,794 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 83998 , Reply# 8   9/19/2005 at 19:21 (6,794 days old) by lavamat_jon (UK)   |   | |
Indesit :-p |
Post# 84056 , Reply# 9   9/20/2005 at 03:59 (6,793 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 84057 , Reply# 10   9/20/2005 at 04:05 (6,793 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 84115 , Reply# 11   9/20/2005 at 10:12 (6,793 days old) by agiflow ()   |   | |
Soon to be Maypool |
Post# 84284 , Reply# 12   9/21/2005 at 06:26 (6,792 days old) by hooverac216 ()   |   | |
hotpoint |
Post# 85504 , Reply# 13   9/27/2005 at 10:09 (6,786 days old) by laundromat (Hilo, Hawaii)   |   | |
top loading? the new Maytag models the agitation stroke goes further as it ossolates back and forth and it spins about 680 rpms with the water in the tub.the tub does not shake back and forth during agitation or spin as the machine has a six point suspension system made of solid steel not thin metal (the direct drive as well as GE's do that a lot) front loading? LG Tromm.This washer does so many things using no pullies,no gears, no belts.The flat direct drive motor is directly connected to the drive shaft like a pully.the tub is on a 10 degree tilt back and the water usage is no more than 18 gallons per load.It can easily wash a full king size bed set with room to spare and the final spin is 1100 rpms!!!! It is so quiet that you could sleep right in front of it!! |
