Thread Number: 33316
could this hoover dryer be considered vintage? |
Post# 501458   3/5/2011 at 06:08 (4,800 days old) by matthewza (Cape Town, South Africa)   |   | |
found this ad herer in SA. want to know if it could be considered vintage |
Post# 501465 , Reply# 1   3/5/2011 at 07:23 (4,800 days old) by ronhic (Canberra, Australia)   |   | |
Post# 501727 , Reply# 2   3/6/2011 at 03:45 (4,799 days old) by matthewza (Cape Town, South Africa)   |   | |
were they any good though? did they dry relatively quick/well and were they reliable? |
Post# 501743 , Reply# 3   3/6/2011 at 07:45 (4,799 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
but just a year or so, if that. You may be able to identify the year from the serial number.
And the answers to your questions are yes, yes and yes. Although we did not have this exact variety of machine, they were popular here and widely sold. They have cropped up quite often in threads. As long as it is not too expensive it would be worth having Al |
Post# 503183 , Reply# 4   3/11/2011 at 07:03 (4,794 days old) by matthewza (Cape Town, South Africa)   |   | |
thankx! will give it some thought |
Post# 503195 , Reply# 5   3/11/2011 at 07:44 (4,794 days old) by alr2903 (TN)   |   | |
The USA versions had a drum that looked like galvanized metal, does that hold true in SA? alr2903 |
Post# 503213 , Reply# 6   3/11/2011 at 09:10 (4,794 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Yes and a Hoover Classic, this was based on the first "MatchBox" style dryer to match the re-styles washing machines, from the big 27inches 9lb load, to the 24inch model 9lb load...Its not reverse action but has a good airflow and two heat settings, High for cottons & robust fabrics and low for man made, synthetics & delicates!! The drums where a heavy vitreous enamel which retained heat and acted very like an iron smoothing the creases out of fabrics!! all you need is a plastic vent on the back!!
