Thread Number: 3334
SQ Water Pump...NOS! |
Post# 83619   9/17/2005 at 14:41 (6,795 days old) by westytoploader ()   |   | |
This looks like it's from the 60's, at the very least, IMHO. CLICK HERE TO GO TO westytoploader's LINK on eBay |
Post# 83640 , Reply# 1   9/17/2005 at 19:06 (6,795 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
Is that a grease fitting I see on the pump? |
Post# 83662 , Reply# 2   9/17/2005 at 21:50 (6,794 days old) by eddy1210 (Burnaby BC Canada)   |   | |
But this one is for the later reversing motor solid tub machines. They are the very same as the older pumps only the bottom cover is reversed so it pumps in the opposite direction. This one could be used in the older machines if you had the correct bottom piece; even reusing your old cover would be fine.
