Thread Number: 3377
After Spin Then Dryer |
Post# 84335 , Reply# 1   9/21/2005 at 11:42 (6,792 days old) by Tomturbomatic (Beltsville, MD)   |   | |
WP & Kenmore combos always used vented drying. |
Post# 84542 , Reply# 2   9/22/2005 at 16:59 (6,790 days old) by toggleswitch (New York City, NY)   |   | |
I had a "Comb-o-matic" [Italian mande] 110v tiny washer-dryer back in 1982 that was vented. SLOW AS HECK DRYER. It had two small openings of about 1.5 inches each and a crude (Read: useless) lint filter near the top, in the rear. A standard 4 inch (100mm) round exhaust hose connection would have been MUCH preferred. It did a 1,000+/- RPM final spin, so that helped it dry somewhat quicker..... |
Post# 84574 , Reply# 3   9/22/2005 at 20:26 (6,790 days old) by kenmore1978 ()   |   | |
I suspect the 110Volt aspect of that machine was more of a problem than the venting system |
Post# 84659 , Reply# 4   9/23/2005 at 06:34 (6,790 days old) by toggleswitch (New York City, NY)   |   | |
Post# 84669 , Reply# 6   9/23/2005 at 08:00 (6,790 days old) by toggleswitch (New York City, NY)   |   | |
Post# 84683 , Reply# 7   9/23/2005 at 08:47 (6,790 days old) by kenmorepeter5 ()   |   | |
If the clothes or towels will dry...it's automatic shut off the timer (complete). - Peter |
Post# 84686 , Reply# 8   9/23/2005 at 08:52 (6,790 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 84699 , Reply# 9   9/23/2005 at 09:17 (6,790 days old) by toggleswitch (New York City, NY)   |   | |
Peter: IIRC (if I recall correctly) the dryer was timed only, not automatic. It went past 120 minutesm which was necessary. Robert: The machine was decent, but i did raise the water level substantially. That may be the reason I stretched the belt, Well that, and overlaoding. (you may need bleach, your post is turning yellow!) I was able to get a replacement belt at the car-parts store. |
Post# 84731 , Reply# 10   9/23/2005 at 10:32 (6,790 days old) by kenmorepeter5 ()   |   | |
I think it's about 2 hours?? Peter |
Post# 84736 , Reply# 11   9/23/2005 at 10:46 (6,790 days old) by toggleswitch (New York City, NY)   |   | |
