Thread Number: 34122
Zanussi de 6754 Dishwasher |
Post# 512345   4/19/2011 at 10:31 (4,755 days old) by ozzie908 (Lincoln UK)   |   | |
Hello Can anyone tell me if the Heater Sensor thats attached to the sump should be open circuit or closed?
I have tested everything I can to find out why this machine won't heat up and all I can find that is open circuit is this small sensor I thought of by passing it to see if its the problem but thought maybe it closes the circuit when it gets hot??? Does anybody know? Austin |
Post# 512353 , Reply# 1   4/19/2011 at 11:10 (4,755 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Post# 512396 , Reply# 2   4/19/2011 at 16:38 (4,755 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 512399 , Reply# 3   4/19/2011 at 16:52 (4,755 days old) by Haxisfan (Europe - UK / Italy)   |   | |
I hope some1 else in this forum will soon give you some expertise on the matter. You could try to bypass it anyway... nothing catastrophic should happen... if it was supposed to close when the temperature is reached then it would cut off the power or, in the opposite instance it might restore power to some other component which in this case could be the heater... which is what you want.
Good luck anyhow ;-) |
Post# 512567 , Reply# 5   4/20/2011 at 07:11 (4,754 days old) by hotpoint9534 (UK)   |   | |
Also try 'elementary diagram' from the same drop down list in the link above. Tom. |
Post# 512632 , Reply# 6   4/20/2011 at 15:35 (4,754 days old) by ozzie908 (Lincoln UK)   |   | |
