Thread Number: 34164
Beko........... |
Post# 512979 , Reply# 1   4/22/2011 at 05:29 (4,752 days old) by Haxisfan (Europe - UK / Italy)   |   | |
If that's the mini 30 (worn once) I had in my 1997 Zanussi then it'll be as useless as useless can get!! Never mind about the good water level during rinses... what about washing? Certainly with its 'less than 10 minute' main wash wasn't able to shift much... however, that cycle was designed for very light soil and for a very small load... it was still useless and pointless as a cycle: all the water loaded during the rinses in such scenario (light soil + small load) was just a mere waste... moreover, it'd just be unsuited for any small as it'd make the garments float with no real action.
I guess the newer Zanussi washers after that model of mine (FL681)... or even other models of the same series (Nexus) in that period weren't as useless!! |
Post# 513548 , Reply# 2   4/25/2011 at 06:52 (4,749 days old) by washerlover24 ()   |   | |
we use it all the time and does the job great i think ....... |
Post# 513650 , Reply# 3   4/25/2011 at 15:33 (4,749 days old) by paulc (Edinburgh, Scotland)   |   | |
Post# 513652 , Reply# 4   4/25/2011 at 15:43 (4,749 days old) by nrones ()   |   | |
Can you tell me how does mainwash lasts on mini 30 in Beko, and what is a max temperature? :) |
Post# 513654 , Reply# 5   4/25/2011 at 15:52 (4,749 days old) by paulc (Edinburgh, Scotland)   |   | |
Post# 513656 , Reply# 6   4/25/2011 at 15:59 (4,749 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Post# 513661 , Reply# 7   4/25/2011 at 16:04 (4,749 days old) by paulc (Edinburgh, Scotland)   |   | |
Post# 513663 , Reply# 8   4/25/2011 at 16:09 (4,749 days old) by dyson2drums (United Kingdom)   |   | |
My cosin has a 6kg 1400rpm model, WMA641 (I think).
They use the cottons wash more or less all the time, although it's pretty long it's got a good performance and the quick button shortens it a little. I have used the 30mins wash, at 30deg celcius and it did exactly as described above but the spin was at max speed (which was selected on the variable spin dial) Not a babd washer for the price :) |
Post# 513671 , Reply# 9   4/25/2011 at 16:23 (4,749 days old) by Haxisfan (Europe - UK / Italy)   |   | |
This kind of cycle is just designed to last that long, in other washers too... it's nearly 3 hours too in my Hoover (could be even longer with some options) and there are a few other brands that feature an even longer standard A40 (up to 5 hours on some larger machines).
I would find it unacceptable if it was the only 40 degree cycle offered by the washer, so, provided that it can be ignored it's harmless really :-P Admittedly though I have used it in a few occasions even at 30 degrees or on cold and it yielded really good results. I wouldn't use it for my everyday laundry though! |
Post# 513679 , Reply# 11   4/25/2011 at 16:44 (4,749 days old) by optima (Cumbria England)   |   | |
Who ever programmes hotpoint Indesit washers needs to go back to school. First of all the slow pointless tumbling instead of just getting on with it. 15 Minute quick wash you would be better off hand washing. That stupid badly designed sports trainer wash. & i have saved the best for last those very silly hotpoint eco cold wash programmes. If i was to tell most of our customers that the 30 minute quick wash programme is done in cold water i could very easily loose a sale so what i tell them is to put it on fast wash @ 60deg programme & turn the temperature down to 40deg thats the only way of getting a decent quick wash in under 1 hour with a fast final spin.
Post# 513683 , Reply# 13   4/25/2011 at 17:03 (4,749 days old) by paulc (Edinburgh, Scotland)   |   | |
Post# 513688 , Reply# 14   4/25/2011 at 17:50 (4,749 days old) by optima (Cumbria England)   |   | |
Post# 513836 , Reply# 17   4/26/2011 at 06:10 (4,748 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Alex, thank you for shedding light over the slow tumble debate.
I feel that most of the bitterness about the slow tumbles in Hotpoint/Indesit machines is not due to the rational usage of these during any standard cycle, but to their inappropriate use and abuse even in situations where they prove utterly inappropriate, e.g. fast wash 30 where the machine uses extremely slow tumble action for 5 minutes and then it speeds up slightly for 3 further minutes: the rest of the cycle time is spent by 2 wasteful rinses and loads of faffing about! Whatever happened to try to save water, when these programmes try to drown your ‘freshen up’ few kilos of laundry! I believe most modern machines envisage an initial phase carried out in such a fashion, and as for the rinses, these are just executed in different ways and they're all effective in their own right. E.g. a high water level rinse yields better results using slower (to a certain extent) or less movements but the same workaround does not apply to a low water level rinse. Having said that, when washing/rinsing something by hand, merely plunging it gently into water doesn't seem to do the trick, some semi-vigorous action is required to shift dirt or detergent: you might not cause suds by reducing the agitation but the detergent would still be trapped in the fibres. I have also noticed that the non-slow tumble action on the defendant is still slower than most other machines, but it doesn't mean that it's inept to do the job… these machines' standard cycles are as good as the next machine! Well, at least I owe it that ;-) |
Post# 513957 , Reply# 20   4/26/2011 at 14:25 (4,748 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Indesit tumbles.
If you take a look at the indesit paddles there are the holes in the top and also grooves in the sides at the tops, the slow tumbles litterally drag water across the load soaking it very well. it doesn't take the load very long to be saturated at all. my aeg would do it to. fill to the rim of the drum and do long slow tumbles for a few minutes. I am actually a fan of these tumbles. The same is applied to there 2 stage rinsing which i've found effective.I'm even considering replacing my soon to be knackered zanussi essential with one as the bearings are going. I actually don't like how my zanussi will static fill without tumbling. it gets on my nerves, it does fast tumbles whips up a load of foam and ends up refilling again. I'm certain they only do this do try and keep water usage and time to a minimum as my zanussi completes a standard cotton 40 in 1hr 20mins. Darren |
