Thread Number: 34253
Can I get parts for my PINK Westinghouse Spacemate Washer?? |
Post# 514250   4/27/2011 at 20:53 (4,747 days old) by daveelias (Cape Coral Florida)   |   | |
Post# 514258 , Reply# 1   4/27/2011 at 21:16 (4,747 days old) by turquoisedude (.)   |   | |
Hmmm... What exactly happened when the spin cycle started? Did the machine suddenly stop or did it blow the house fuse when the spin cycle engaged??
My 1950 L5's 'cause of death' was a bad spin solenoid - it had shorted and caused the machine to stop as it engaged into the spin. The good news is that I did manage to find a NOS replacement at Modern Parts in Ohio. I guess you mean the door seal gasket - not sure what the exact part number is but there are LOTS of Westinghouse parts that will be available soon at an appliance repair shop in Queensbury NY (Hansen's) and I do believe there were some door boots there... |
Post# 514474 , Reply# 4   4/28/2011 at 19:09 (4,746 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi dave you can Email me your phone # and I will try to help you figure out what is going wrong John.
3BW very little of what you wrote is correct, all the wattage's, RPMs, and HP of the motor are incorrect you have probably never seen one of the 25" machines let alone repaired one. And their is no potato pulley on these machines. |
Post# 515372 , Reply# 8   5/3/2011 at 04:19 (4,742 days old) by rp2813 (Sannazay)   |   | |
I had a basket case of a 1950-ish Laundromat that I used for a while when I lived in a rental with laundry hook-ups in the garage. Good thing, because the tub leaked. I sold it a few years ago when I admitted to myself that I'd never restore it. I really love the old Westy Laundromats because they're fun to watch and cute to look at.
Now I have yet another reason to love them: they employ something called a potato pulley (unless this agricultural reference applies only to later models).
Regardless, would anyone care (or considering the exchanges above, dare) to do the 'splainin on the relationship between spuds and suds? |
Post# 515392 , Reply# 9   5/3/2011 at 08:12 (4,742 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Ralph and others all the WH washers used a two belt drive with a SEALED IN STEEL gear box or speed changer till the mid 1950s. Then around 1955 the three belt drive system was brought out on the new 25" compact washer it was also being phased in on the larger 30" slant front models and all 1957-8 slant fronts also had the 3B drive. The 3BD was redesigned somewhat in 1959 just for the full sized slant front 30" models. They had a horizontal tub with just two plastic baffles that were not evenly spaced and this is where the famous potato pulley was added the allowed the speed of the wash basket to vary with every revolution. These washers also added two HD hydraulic automotive type shocks to better control vibration during spin [ Bendix had already been using H shocks on there combos and non bolt down FL washers ]. The 25" SM drive system continued with no real changes till 1963 when they went to 27" and the large SF 30" were changed down to the same 27" machine. At this point all WH FL washers were the same, they did make both stackable and rear control versions. These smaller machines did loose the much better hydraulic shocks and went back to the noisy troublesome friction snubbers. The 3BWs continued till mid 1988 with little change, they did loose the better cast iron counter balance weight in the early 1970s and when to five blocks of cement instead.
The 27" machine was redesigned and reintroduced in 1989 after a 6 month period when we couldn't get any WWH FLers at all. The new machine looked almost like the old 3B machine and it was built in the same US plant. But as White Industries had been purchased by Electrlox of Sweden the new machine was very different inside. They scraped the drive system, water pump and timer. They used a DC brush type motor with a single belt, the new motor, electric drain pump, timer, friction shocks and speed control board were all made in Italy [ some of the main motors were also German ]. These new machines performed well at first even getting a top recommendation from Consumer Reports for good efficiently. But the machines were a disaster I could go on and on about the problems, Electroxs hi bread machine combined the worst of WH and European technology. CRs rescinded thier recommendation within two years because of all the repair problems. These single belt machines were made well into 1993 and then there was another lapse in availability of FL washers of almost one year till they brought out the all new Frigidare FLer in late 1995.
None of the WH FL washers ever had great water extraction till the 1995 models, you were lucky if they extracted as well as a WP BD washer. All WH FL washers had 1/3 HP, 1725 RPM motors till the mid 1960s [ including all 25" models ] when they went to 1/2 HP during the HP race of the 1960s [ none ever had a 1800 RPM motor]. The pump speed on all WH FL washers was around 2000 RPMs [ not 220 ]till they they went to a separate electric pump in 1989. |
