Thread Number: 34266
HELP, Please - WU902 Maytag Dishwasher |
Post# 514394 , Reply# 1   4/28/2011 at 12:45 (4,747 days old) by rp2813 (Sannazay)   |   | |
Check out this thread. Maybe Paul can provide you with some advice or parts if needed. CLICK HERE TO GO TO rp2813's LINK |
Post# 514471 , Reply# 2   4/28/2011 at 19:05 (4,746 days old) by turquoisedude (.)   |   | |
OMG what a wild coincidence! The wiring diagram is in pretty bad shape, but I will bring it back to town and try scanning it for you.
I have a funny feeling there might be timer issue, but I am not sure. If you hit the CANCEL/DRAIN button does anything happen? The timer should click and you should see the wash, rinse, and dry lights light up in succession. If that's the case, the timer may be OK... After the fill completed, did you hear water moving around in the tub or did you just hear the motor running? It might be belt that is slipping, too. |
Post# 514593 , Reply# 4   4/29/2011 at 11:47 (4,746 days old) by turquoisedude (.)   |   | |
I remember that I had to hold the Cancel/Drain button down for about 10 or 15 seconds to engage it, but once it did engage, you would hear the timer clicking and the machine would (if I remember correctly) drain, then cycle through WASH-RINSE-DRY, then shut off.
It may just be that the dishwasher needs to be hooked up to the water supply to be tested... But, I am used to working on the really old dishwashers with a 'timed fill' so manually advancing the timer will bring them through the different cycle phases.
Stand by for the wiring diagram - I'll be down at the house in Ogden as of tonight and should be able to scan it for you early next week. |
Post# 515384 , Reply# 5   5/3/2011 at 07:00 (4,742 days old) by turquoisedude (.)   |   | |
Post# 515572 , Reply# 6   5/4/2011 at 07:01 (4,741 days old) by suby4me ()   |   | |
No Problem, We patiently await your assistance. Thanks.. |
Post# 515596 , Reply# 7   5/4/2011 at 08:54 (4,741 days old) by turquoisedude (.)   |   | |
I got a better result using the scanner at work (better resolution than the very basic one I have at home!) but it is too big to upload to the board!! AAARGH!!
I will try emailing you the page directly - if that doesn't work, please let me know your mailing address or a fax number where I can send them!
Sorry for the hassle!!
Post# 515770 , Reply# 10   5/5/2011 at 06:24 (4,740 days old) by CUFFS054 (MONTICELLO, GA)   |   | |
TDude, may be right. Aunt's MTag required holding any of the cycle buttons down till cycle actually started to go. Cancel/drain was the same. Love that d/w. |
