Thread Number: 34443
Early 806's |
Post# 516690   5/9/2011 at 20:46 (4,747 days old) by qsd-dan (West)   |   | |
Washer still has the original 8 finned agitator. Both units should have the incandescent timer light in addition to the florescent. Asking price is very modest.
CLICK HERE TO GO TO qsd-dan's LINK on Minneapolis Craigslist |
Post# 516694 , Reply# 1   5/9/2011 at 21:12 (4,747 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 516706 , Reply# 2   5/9/2011 at 22:13 (4,747 days old) by rp2813 (Sannazay)   |   | |
Post# 516710 , Reply# 3   5/9/2011 at 22:32 (4,747 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 516886 , Reply# 4   5/10/2011 at 18:26 (4,746 days old) by Kenmore71 (Minneapolis, MN)   |   | |
...and closed the deal. By tomorrow they'll be in my basement. Pics will follow then.
The owner used the washer as recently as a month ago and the dryer in January. He quit using the dryer because "it wouldn't ever shut off." First guess would be that the electrolytic capacitors in the sensing circuitry have drifted. They have obviously been used a lot but were extremely well taken care of. If you count the guy who's been in the house for 6 months, I will be the 3rd owner. |
Post# 516893 , Reply# 5   5/10/2011 at 18:46 (4,746 days old) by rp2813 (Sannazay)   |   | |
Post# 516895 , Reply# 6   5/10/2011 at 18:53 (4,746 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 516907 , Reply# 7   5/10/2011 at 19:27 (4,746 days old) by AutowasherFreak ()   |   | |
NICE set of Tags, I'm sure you will enjoy them.
Post# 516920 , Reply# 8   5/10/2011 at 20:17 (4,746 days old) by redcarpetdrew (Fairfield, CA)   |   | |
First off, CONGRATULATIONS!
A Halo of Heat that will not shut off can have a problem that ranges from the simple to the nasty... 1) The little paperclip like link from the shut off solenoid to the control switch can be off or broken. (common) 2) Bad shutoff solenoid. (not likely) 3) The element can be grounded and won't cool down and let the cool down t-stat shut the motor off even though the control switch may have 'turned off' (common) 4) Bad cool down stat. (common) 5) Bad/broken control switch. (possible) 6) Bad electronic dry board. (uncommon) 7) Possible short across one of the sets of sensor bars in the drum (possible) Do a little triage when they come home and let us know! Otherwise, that's a nice set! RCD |
Post# 516929 , Reply# 9   5/10/2011 at 21:03 (4,746 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
Post# 517136 , Reply# 10   5/11/2011 at 23:34 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517137 , Reply# 11   5/11/2011 at 23:36 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517138 , Reply# 12   5/11/2011 at 23:38 (4,745 days old) by Spankomatic (Ukiah,CA)   |   | |
Post# 517139 , Reply# 13   5/11/2011 at 23:40 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517140 , Reply# 14   5/11/2011 at 23:41 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517141 , Reply# 15   5/11/2011 at 23:42 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517142 , Reply# 16   5/11/2011 at 23:43 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517143 , Reply# 17   5/11/2011 at 23:44 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517144 , Reply# 18   5/11/2011 at 23:45 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517145 , Reply# 19   5/11/2011 at 23:47 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517146 , Reply# 20   5/11/2011 at 23:48 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517147 , Reply# 21   5/11/2011 at 23:49 (4,745 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517149 , Reply# 22   5/12/2011 at 00:29 (4,745 days old) by jetaction (Minneapolis)   |   | |
Post# 517151 , Reply# 23   5/12/2011 at 00:39 (4,745 days old) by rp2813 (Sannazay)   |   | |
Post# 517164 , Reply# 24   5/12/2011 at 06:10 (4,745 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 517174 , Reply# 25   5/12/2011 at 07:31 (4,744 days old) by bajaespuma (Connecticut)   |   | |
Incredible machines! How I would love to help restore those classics to their original glory. It's ironic; Maytag washers have outlived the Maytag company.
Be careful cleaning that lint filter; it's not as hardy as the later versions. Soak the BOTTOM MESH PART ONLY in some Lime-Away overnight being very careful not to let any of the acid get on that beautiful chrome cap. Hot water and a brush should then do the rest easily.
If you have time, would you be able to post a couple of close-up pics of the gas flame emblem on the control panel and the model plate on the gas dryer? |
Post# 517187 , Reply# 26   5/12/2011 at 08:37 (4,744 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 517196 , Reply# 27   5/12/2011 at 10:05 (4,744 days old) by steve1-18 (Grovetown (Augusta), GA)   |   | |
I have the exact same set with the electric dryer. Does yours have the tub light? |
Post# 517202 , Reply# 28   5/12/2011 at 10:55 (4,744 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Great find, congratulations. BAJA's advice on the filter is correct, keep the silver part dry but soak the bottom in Lime-Away or CLR, and I used a fingernail brush and pushed through the holes, got out TONS of ugly fine crap. Now, a two-second rinse under the faucet after each wash keeps it spotless. And it does a fine job, lots of lint.
I happen to have a Halo-Of-Heat service manual, up to DG700 and 701, only slightly before your machine. If it can be of help, feel free to ask-- Congrats on your new find, solid and responsible machines. And a matched set! |
Post# 517225 , Reply# 29   5/12/2011 at 13:07 (4,744 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
Post# 517328 , Reply# 30   5/12/2011 at 23:18 (4,744 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517329 , Reply# 31   5/12/2011 at 23:19 (4,744 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517333 , Reply# 32   5/12/2011 at 23:36 (4,744 days old) by Spankomatic (Ukiah,CA)   |   | |
Post# 517374 , Reply# 33   5/13/2011 at 07:47 (4,743 days old) by GadgetGary (Bristol,CT)   |   | |
Post# 517391 , Reply# 34   5/13/2011 at 08:44 (4,743 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517394 , Reply# 35   5/13/2011 at 08:44 (4,743 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517395 , Reply# 36   5/13/2011 at 08:45 (4,743 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517396 , Reply# 37   5/13/2011 at 08:47 (4,743 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517448 , Reply# 38   5/13/2011 at 12:29 (4,743 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517449 , Reply# 39   5/13/2011 at 12:30 (4,743 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 517470 , Reply# 40   5/13/2011 at 13:56 (4,743 days old) by rp2813 (Sannazay)   |   | |
Post# 517742 , Reply# 41   5/14/2011 at 12:55 (4,742 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Yesterday I spent the day working on the machines in a very general way.
- I got the washer lint filter clean by soaking the plastic part in vinegar overnight (the metal is fine) and then scrubbing it in hot dishwater using an old toothbrush. It cleaned up very nicely. - The washer will be needing some work on the motor glides and/or springs and possibly a new set of belts. When I put full of a load of whites in it took quite a bit of coaxing to get it to agitate even moderately. The spin was pretty anemic. I ended up transferring the VERY wet laundry to another machine to spin it out again before putting it in the dryer. - Somewhere along the line the pump was replaced and whoever did that did not reconnect the bleach dispenser "dilution" hose to the pump. I can see a plastic "stub" on the top of the pump where I think this should go. Is it as simple as drilling a small hole in the indentation in that stub and reconnecing the hose to the bleach dispenser? - Other than those issues and a thorough cosmetic "spa" treatment I think the machine is in VERY good shape. Tub bearing seems quiet and stable, no leaks, tub brake seems tight, no indexing during agitation (although I supppose that could change when the agitation is up to snuff.) I am particularly impressed with the SUBSTANTIAL feel of the timer knob when you turn it. It just has this feel of quality that I have rarely experienced. Now the dryer: - There is problem somewhere in the electronics with the shut off. The only setting that seems to work properly is DAMP DRY. When the dryer is empty, DAMP dry shuts off within about 5 seconds. When I put the full load of whites in on DAMP DRY, it ran normally and shut off after about 45 minutes and the load was appropriately damp. When I tried "REGULAR" with the machine empty it ran for 20 minutes before I finally intervened. With the damp whites in, I pushed REGULAR and let it run for about 20 minutes before checking. They were definitely DRY. From the literature I have looked at, this sounds like a fairly common problem with this electronic control. Ben, Gregg, Dan - thoughts? |
Post# 517832 , Reply# 42   5/14/2011 at 17:40 (4,742 days old) by swestoyz (Cedar Falls, IA)   |   | |
Like timers, the Maytag Electronic Control module does get blamed for many issues since it controls everything the dryer does, and they do go bad.
However, there are a few other things that could go wrong as well - grounding issues, dirty baffles, broken wires, etc. Follow the steps outlined on the five pages below for the wire wrapped baffles (wire wrapped baffles are from 1961- early 1969). I've also included the checks for the bar baffles in case someone uses this in the future for HOH dryers made up to 1975. (BTW - both the washer and dryer were made in March of 1967). |
Post# 517833 , Reply# 43   5/14/2011 at 17:40 (4,742 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 517834 , Reply# 44   5/14/2011 at 17:41 (4,742 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 517835 , Reply# 45   5/14/2011 at 17:41 (4,742 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 517837 , Reply# 46   5/14/2011 at 17:42 (4,742 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 517838 , Reply# 47   5/14/2011 at 17:45 (4,742 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
On the original wire wound drum baffle machines like you have they would often do this as they age. Dan suggested replacing the large capacitor on the electronic control, this may work? But I have often clipped the wires going to one or even two of the drum baffles and the machine will then work fine. There many other things that you may want to check such as grounding of the dryer, also clean the baffles with rubbing alcohol.
Mark it is usually best when you have problems with older machines to ask folks that work on machines for a living and people old enough to remember such machines LOL. |
Post# 518036 , Reply# 48   5/15/2011 at 16:02 (4,741 days old) by qsd-dan (West)   |   | |
Yeah, replacing the belts, glides/springs, and lubricating the pump is SOP for any machine I procure. Replacing brake packages is becoming an additional step these days for me. Somewhere along the line the pump was replaced and whoever did that did not reconnect the bleach dispenser "dilution" hose to the pump. I can see a plastic "stub" on the top of the pump where I think this should go. Is it as simple as drilling a small hole in the indentation in that stub and reconnecting the hose to the bleach dispenser? Yes. Actually, the pre-FSP pumps had the diameter drill bit to use right on the package. I forget what the exact drill bit diameter is at this moment, but 5/16 keeps popping into my head. I am particularly impressed with the SUBSTANTIAL feel of the timer knob when you turn it. It just has this feel of quality that I have rarely experienced. Sounds like you have a Mallory timer. Mallory timers have a very "notchy" feel to them. There are a few 203182 Kingston timers for this machine on Ebay that you may want to swipe for the future. There is problem somewhere in the electronics with the shut off. The only setting that seems to work properly is DAMP DRY. When the dryer is empty, DAMP dry shuts off within about 5 seconds. When I put the full load of whites in on DAMP DRY, it ran normally and shut off after about 45 minutes and the load was appropriately damp. When I tried "REGULAR" with the machine empty it ran for 20 minutes before I finally intervened. With the damp whites in, I pushed REGULAR and let it run for about 20 minutes before checking. They were definitely DRY. From the literature I have looked at, this sounds like a fairly common problem with this electronic control. Ben, Gregg, Dan - thoughts? 5 second shut-off for an empty drum on "Damp Dry" is a little too early. Should be 7-17 sec. Maytag had 2 electronic control units for the 606/806/906. I've only worked the common 303049 ones, so I'm guessing the uncommon 302472 are for the early units?? Not sure if they're interchangeable or not but it wouldn't surprise me if they actually are interchangeable. Start by checking the condition of the slip ring and brush. Make sure the slip ring is clean and the brush has enough "meat" on it. From there, replace the original electrolytic capacitor on top of the elect. unit with a film cap of the same specs. Sometimes the original capacitor is covered by a rubber sheath that you must remove to get the farad and voltage ratings. If all else fails, both style electronic control units are currently available on ebay in new/unused condition. |
Post# 518257 , Reply# 49   5/16/2011 at 12:06 (4,740 days old) by rickr (.)   |   | |
Congratulations Dan! Very nice set!
I am just finishing an 806 gas dryer, and had to do quite a bit of restoration on the wiring. The connectors just corroded away to nothing in some areas. I converted this dryer to electronic ignition, because I don't want the wiring problems to come back again. My dryer is working fine now. I wonder if you need to do some cleaning to the connections inside the dryer, selector switch and control module? I had to a few hours worth of wiring/connector repair to make this dryer work right. I think tight corrosion free connections are very important for the electronic control to work as it should. Best of luck with your classic Maytag set! |
Post# 518960 , Reply# 50   5/18/2011 at 22:23 (4,738 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 518961 , Reply# 51   5/18/2011 at 22:24 (4,738 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 518962 , Reply# 52   5/18/2011 at 22:24 (4,738 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 519025 , Reply# 53   5/19/2011 at 07:03 (4,738 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
When we used to see the electronic dryers that had a lot of corrosion from the byproducts of combustion caused by the constantly burning pilot I would solder the individual terminals on the circuit board to the board. This trick restored several HOH electronic gas dryers to proper operation that MT Service of Washington told owners could not be fixed.
Rick please post pictures of your electric ignition conversion, I started one on a pink 741C dryer last year but it got side tracked by the washer convention. I used the burner assembly from a newer early 1980s MT gas dryer, I will finish the assembly and post pictures of the results when I can get it back into my test shop where we have gas connections.
If anyone wants a pink fully restored MT gas dryer model 741C let me know although Bob of Hollywood will have the first crack at it as he helped me get the project started last year.. |
Post# 519037 , Reply# 54   5/19/2011 at 08:00 (4,737 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 519042 , Reply# 55   5/19/2011 at 08:18 (4,737 days old) by rickr (.)   |   | |
Post# 519117 , Reply# 56   5/19/2011 at 16:52 (4,737 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 519348 , Reply# 57   5/20/2011 at 16:42 (4,736 days old) by rll70sman (Hastings, Minnesota)   |   | |
Great washer and dryer! Love the nostalgic handwritten invoice! Note how there was no sales tax charged. This set was purchased just prior to passage of the Minnesota sales and use tax law, which took effect August 1, 1967 at a mere 3 percent. |
Post# 971288 , Reply# 58   12/3/2017 at 13:50 (2,347 days old) by Maytag85 (Sean A806)   |   | |
