Thread Number: 35277
Easy Automatic quadra speed on the control panel |
Post# 527271 , Reply# 1   6/27/2011 at 20:27 (4,685 days old) by appnut (TX)   |   | |
Post# 527329 , Reply# 2   6/28/2011 at 10:11 (4,685 days old) by appliguy (Oakton Va.)   |   | |
Usually machines that had 2 drain hoses were Suds Saver models...I highly suspect that the washer your grandma had might be a Suds Saver. If each hose went into its own seperate tub or if one went into a tub and the other into a stand pipe or another drain then I highly suspect that machine was a Suds Saver......I am I correct in my suspicions guys? PAT COFFEY |
Post# 527410 , Reply# 3   6/28/2011 at 17:47 (4,685 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Hi Pat
Your suspicions are correct: most machines in Australia that had two outlet hoses were Suds Saver models with the 'automatic' suds saver with the divertor valve.
The divertor valve saves the wash water into one tub and flushes any rinse water down the drain or into another tub through the 2nd hose.
Very common on a lot of automatic machines sold in Oz up till the 1980's. Most of my collection have the Suds Save facility.
Cheers Leon |
Post# 527937 , Reply# 4   6/30/2011 at 20:38 (4,682 days old) by appnut (TX)   |   | |
Post# 527949 , Reply# 5   6/30/2011 at 21:47 (4,682 days old) by appnut (TX)   |   | |
