Thread Number: 35957
1958 Washer/Dryer combo |
Post# 536212 , Reply# 1   8/10/2011 at 16:00 (4,643 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hi Dex, I don’t pretend to know everything about combo washer/dryers, but I’ll give it my best shot here…. The Whirlpool combo (in the video) and the Kenmore / Lady Kenmore cousins both use the recirculating water spray as there is NO standing water in the tub/drum (unlike other FL washers). The water stays in a reservoir below, is sprayed onto the clothes and then drains back to the reservoir. This design had VERY little (read: no) suspension, so the spin speed was limited to just 200 RPM. Because of this low RPM, water extraction is poor, so they packed in a lot of drying power. My 1959 Lady Kenmore combo (pink!) is gas and cranks out 37,000 BTU’s (today’s new dryers look to be 20,000 – 22,000 BTU’s) This Whirlpool/Kenmore design was revised and improved in 1961 (I believe) adding a better suspension, a much better 525 RPM spin, a whole host of other changes and packed it into a smaller package. BTW, this design must have worked and sold well because it was available under the Kenmore/Lady Kenmore label from 1961 thru 1972 or so (I believe). While nearly every manufacturer in the 50’s – early 60’s offered a “Combo”, many didn’t stay on the market long for one reason or another. One company that set the standard (and held a number of patents) through the 50’s anyway, was Bendix. The patent on their suspension system severely limited what other manufacturers were able to do with their designs, hindering their performance and/or reliability greatly. My understanding is the newer Combos available here in the US (LG for example) have a VERY long total cycle time, something like 3.5 – 4 hours for wash & dry. I believe that’s because they use electric drying (as opposed to gas) and with the 120 volt power we have in the US, limits drying power and thus, speed. It’s like trying to dry a load of clothes with a 1200-1500 watt hair dryer. I don’t know if it makes any difference if the unit is vented, or non-vented (condensing) dryer. Correct me if I’m wrong, but *I think* a condensing dryer would take longer to dry. Our regular, separate electric dryers are 220-240 volts (4400 – 5600 watts) and have “normal” drying times. I hope this helps! Kevin P.S…. if you go back and look at the other videos I’ve up loaded, you will find videos for a 1965 Lady Kenmore combo and a 1957 or ‘58(?) Bendix Duo-matic (combo). This post was last edited 08/10/2011 at 16:20 |
Post# 536292 , Reply# 3   8/10/2011 at 21:24 (4,643 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
the Combo was invented by Bendix Home Appliances in 1949 here in the US. Anyone else making that claim has to come up against the direct patent evidence here first! Lets kill that notion that the Combo was invented in Europe at all! Europe adopted it much quicker than the US did but that is its only claim!
Condenser drying is very quick and very good for wool and cottons that tend to shrink in air blow dryers and most everything else , where it falls down is on poorly made clothing that has cheap dyes stuffs and will cause 'Crocking" , the dye will wipe across the rest of the load at the high heat and humidity of condenser drying. |
Post# 536331 , Reply# 5   8/11/2011 at 05:59 (4,642 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 536879 , Reply# 8   8/14/2011 at 06:34 (4,639 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
