Thread Number: 36136
KDC 12P Found! |
Post# 538558   8/21/2011 at 16:14 (4,645 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Went to craigslist this, new home owners throwing out old homeowners stuff. I asked him what made him not just put it out on the curb for trash, and this is what he said: I went on line and found this guy who had one and had put a big window in it to see what was going on inside so I figured someone else might like it! He sure was right, now I wonder who that guy was with the window dishwasher hmmmm???
Post# 538560 , Reply# 1   8/21/2011 at 16:17 (4,645 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538562 , Reply# 2   8/21/2011 at 16:17 (4,645 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538563 , Reply# 3   8/21/2011 at 16:18 (4,645 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538564 , Reply# 4   8/21/2011 at 16:19 (4,645 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538566 , Reply# 5   8/21/2011 at 16:19 (4,645 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538570 , Reply# 6   8/21/2011 at 16:22 (4,645 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538579 , Reply# 7   8/21/2011 at 16:34 (4,645 days old) by appnut (TX)   |   | |
Jon, I may be totally off-base here, but I remember the POD earlier this week of the 14 series and in one of the 3 depictions of during the day of the the dishwasher "day", it had the smaller plates loading at a say 45 degree angle on the side off of the edge of the center dinner plates, fanned all the way back from front to back. |
Post# 538581 , Reply# 8   8/21/2011 at 16:37 (4,645 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538583 , Reply# 9   8/21/2011 at 16:41 (4,645 days old) by appnut (TX)   |   | |
Post# 538698 , Reply# 12   8/22/2011 at 08:22 (4,644 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
the rest of the machine looks healthy, I contacted that guy in NY about his machine we'll see what happens. I think the pump looks healthy, I put water in the tub and it only came out the pump drain hole, so the seals are good. Of course the water flowed out the drain valve, the other side you can't see has a 1 inch hole in it, you can see the valve plate. It looks like the cast iron expanded due to rust and it has split the bakelite trap. How important is that trap? Can the machine run without it or will the drain air lock?
Thanks Tom for the info now I think I know how to load it!
Post# 538707 , Reply# 14   8/22/2011 at 09:06 (4,644 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538750 , Reply# 15   8/22/2011 at 11:35 (4,644 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Jon, sort of a lazy 90 degrees. They leaned back also. Of course, I guess it depends on the thickness of the dishes. Dishes were thinner back then; there was not so much of the heavy clunky stoneware. |
Post# 538879 , Reply# 16   8/22/2011 at 21:08 (4,643 days old) by JETCONE (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 538925 , Reply# 17   8/23/2011 at 05:06 (4,643 days old) by appnut (TX)   |   | |
Post# 538926 , Reply# 18   8/23/2011 at 05:08 (4,643 days old) by appnut (TX)   |   | |
Post# 538935 , Reply# 19   8/23/2011 at 07:24 (4,643 days old) by norgeway (mocksville n c )   |   | |
Is a dishwasher, not like these weak kneed things they sell today! |
Post# 538936 , Reply# 20   8/23/2011 at 07:26 (4,643 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Nice dishwasher. Just for fun, compare the stainless front on yours to one at the appliance store today - you could ram your tricycle into yours over and over and never hurt it, don't try that with a new Frigidaire!
I couldn't get the trap on my 14P to stop seeping water so I chucked it, just run a hose from the drain valve (well, a good drain valve) to the pump inlet and you'll be fine.
You'll like your 14 rack better than the rails on the 12, they limited loading options a lot. I think Robert has a 14 lower rack in their 12 with the window. |
Post# 538942 , Reply# 21   8/23/2011 at 08:12 (4,643 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 538983 , Reply# 23   8/23/2011 at 11:57 (4,643 days old) by Unimatic1140 (Minneapolis)   |   | |
What kind of weirdo would do something like that????? Yes in my "Pimp my KitchenAid" dishwasher, with the window, I use the 14 Racks (both upper and lower) BUT I use the 12's Silverware basket which I think is much better. |
