Thread Number: 36644
RESCUED and FOUND!!!! |
Post# 545292   9/23/2011 at 07:22 (4,599 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
First Kitchen Aid Dishwasher. A beauty! This popped up on Craigslist last week, emailed the owner and asked if it was still available. The response Hi Jon. The dishwasher is actually still installed in our kitchen, but we could have it removed by the weekend if you are serious about the dishwasher and coming to buy it. When on Saturday would you be here? Thanks, Pam"
And actually it was used the Friday nite before I came Saturday! 60 years in service! Now ya wanna see the pics?? |
Post# 545293 , Reply# 1   9/23/2011 at 07:23 (4,599 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545294 , Reply# 2   9/23/2011 at 07:24 (4,599 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545295 , Reply# 3   9/23/2011 at 07:24 (4,599 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545296 , Reply# 4   9/23/2011 at 07:25 (4,599 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545297 , Reply# 5   9/23/2011 at 07:25 (4,599 days old) by wringingwet (Walterboro South Carolina)   |   | |
Post# 545298 , Reply# 6   9/23/2011 at 07:27 (4,599 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545299 , Reply# 7   9/23/2011 at 07:30 (4,599 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545300 , Reply# 8   9/23/2011 at 07:31 (4,599 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545301 , Reply# 9   9/23/2011 at 07:32 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545314 , Reply# 11   9/23/2011 at 08:51 (4,598 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 545316 , Reply# 12   9/23/2011 at 08:57 (4,598 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545317 , Reply# 13   9/23/2011 at 09:03 (4,598 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
and has a comlpete metal cabinet kitchen, couldn't quite see the label, it wasn't Youngstown.
They are the third owners and are restoring the cabinets and searching for a "retro" dishwasher whatever that means I'm not sure. But they were using this right up till I bought it. You couldn't get more retro than a KD-10. |
Post# 545319 , Reply# 14   9/23/2011 at 09:11 (4,598 days old) by Toggleswitch (New York City, NY)   |   | |
Post# 545331 , Reply# 15   9/23/2011 at 10:10 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545335 , Reply# 16   9/23/2011 at 10:17 (4,598 days old) by jetaction (Minneapolis)   |   | |
Post# 545337 , Reply# 17   9/23/2011 at 10:20 (4,598 days old) by appnut (TX)   |   | |
Post# 545343 , Reply# 18   9/23/2011 at 10:39 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
it is SOOO SIMPLE I can't believe they changed it out. That tube just has a rubber seal around the bottom and it just lifts up for drain just like a sink plunger in your bathroom sink. Its all brass under thare too! And the tube is all sized for automatic overflow without adding another pressure switch to the mix. |
Post# 545344 , Reply# 19   9/23/2011 at 10:39 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545345 , Reply# 20   9/23/2011 at 10:40 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545346 , Reply# 21   9/23/2011 at 10:43 (4,598 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 545348 , Reply# 22   9/23/2011 at 10:46 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
drainulation: You can see the solenoid linkage to the right, as the solenoid robot engages it forces the tube and seal inside the tub down to seal and when it goes off it forces the tube up and all the waste water swhooshes away down the brass drain pipe. The motor sits transverse and just bolts to the side of the sump directly to the pump inside the machine.
Post# 545349 , Reply# 23   9/23/2011 at 10:47 (4,598 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 545350 , Reply# 24   9/23/2011 at 10:49 (4,598 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 545351 , Reply# 25   9/23/2011 at 10:49 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545354 , Reply# 26   9/23/2011 at 10:59 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545355 , Reply# 27   9/23/2011 at 11:00 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545356 , Reply# 28   9/23/2011 at 11:01 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545362 , Reply# 29   9/23/2011 at 11:34 (4,598 days old) by peteski50 (New York)   |   | |
Post# 545364 , Reply# 30   9/23/2011 at 11:40 (4,598 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 545395 , Reply# 31   9/23/2011 at 13:06 (4,598 days old) by appnut (TX)   |   | |
Post# 545410 , Reply# 32   9/23/2011 at 14:21 (4,598 days old) by stevet (West Melbourne, FL)   |   | |
Since perfection cannot be rushed, here is the next progression of the original to the vertical style pump and more familiar pump setup. CLICK HERE TO GO TO stevet's LINK |
Post# 545503 , Reply# 33   9/23/2011 at 21:25 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545510 , Reply# 34   9/23/2011 at 21:44 (4,598 days old) by A440 ()   |   | |
Awesome Find Jon!!!! What a beauty! Thanks for the pictures. Brent |
Post# 545511 , Reply# 35   9/23/2011 at 21:49 (4,598 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545512 , Reply# 36   9/23/2011 at 21:51 (4,598 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 545516 , Reply# 37   9/23/2011 at 22:09 (4,598 days old) by A440 ()   |   | |
Thanks Jon! Hugs with Phosphate Cascade on Top! Brent |
Post# 545533 , Reply# 38   9/23/2011 at 23:08 (4,598 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 545542 , Reply# 39   9/24/2011 at 00:37 (4,598 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 545546 , Reply# 40   9/24/2011 at 01:27 (4,598 days old) by pdub (Portland, Oregon)   |   | |
Post# 545551 , Reply# 41   9/24/2011 at 02:15 (4,598 days old) by earthling177 (Boston, MA)   |   | |
Cool, congratulations and enjoy it in good health! |
Post# 545555 , Reply# 42   9/24/2011 at 06:00 (4,598 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 545560 , Reply# 43   9/24/2011 at 07:35 (4,597 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
I thought this was the machine you told me about back in July. As I remember you said you had spoken to her back in May-June???At first I couldn't believe it! And was surprised it was still listed for sale when it popped up on a CL search.
I'm gonna plumb it in as a gravity drain to keep it original as possible!! You're gonna have to come back up and play again soon!
They were a very nice young couple who didn't want to see this machine go to the "krusher". I was impressed by that.
Enjoy all!
jon |
Post# 545705 , Reply# 44   9/25/2011 at 07:32 (4,596 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 545859 , Reply# 45   9/26/2011 at 05:28 (4,596 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
