Thread Number: 36730
KitchenAid dishwasher |
Post# 546498 , Reply# 1   9/29/2011 at 20:24 (4,592 days old) by Jitterbug ()   |   | |
Scratch that; KD2P, sorry. |
Post# 546505 , Reply# 2   9/29/2011 at 21:15 (4,592 days old) by appnut (TX)   |   | |
Post# 546510 , Reply# 3   9/29/2011 at 21:18 (4,592 days old) by Jitterbug ()   |   | |
It is toploading. What are some common culprits? |
Post# 546519 , Reply# 5   9/29/2011 at 21:57 (4,592 days old) by stevet (West Melbourne, FL)   |   | |
This should have gone with the thread with the Craigslist ad! Robert, can you move it? If not, just delete it if you can. Thanks Steve |
Post# 546541 , Reply# 6   9/30/2011 at 01:01 (4,591 days old) by sudsmaster (SF Bay Area, California)   |   | |
If it's a top loading KD2-P, then it's a classic machine that is worth saving. The leak could be something as simple as a bad hose. Or it could be a bad seal, gasket in the pump.
I have a KD2P and I believe so does Robert (the webmaster). Mine works perfectly and really sends out a power spray of water. It's also an attractive 50's period appliance, what with its rounded corners and chrome handle/vent assembly up top. |
Post# 546595 , Reply# 7   9/30/2011 at 08:59 (4,591 days old) by Jitterbug ()   |   | |
What is the tubing made of? |
Post# 546724 , Reply# 8   10/1/2011 at 05:07 (4,590 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 546725 , Reply# 9   10/1/2011 at 05:08 (4,590 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 546726 , Reply# 10   10/1/2011 at 05:11 (4,590 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 546729 , Reply# 11   10/1/2011 at 05:54 (4,590 days old) by polkanut (Wausau, WI )   |   | |
Post# 546756 , Reply# 12   10/1/2011 at 10:07 (4,590 days old) by appnut (TX)   |   | |
Post# 546765 , Reply# 13   10/1/2011 at 11:19 (4,590 days old) by Jitterbug ()   |   | |
It looks just like that. Oh, I shall remember the drain valve. How may one replace the hoses that connect the washer to the sink? |
Post# 546840 , Reply# 16   10/1/2011 at 22:18 (4,590 days old) by Jitterbug ()   |   | |
Oh, this gives me hope. What sort of tubing should I use, the clear vinyl or try to find the black rubber? |
Post# 547022 , Reply# 17   10/3/2011 at 06:52 (4,588 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
