Thread Number: 36856
New SQ AWN432 - First Spin |
Post# 548296   10/9/2011 at 14:25 (4,583 days old) by llmaytag (Southern California)   |   | |
So now I have my new SQ AWN432 and it works pretty good...feels much more solid than the Whirlpool. Not quite like the original Maytag DC, but very close. Observations:
Quiet Much quieter than the Whirlpool. The loudest point is the brake when it stops spinning. Agitation is smooth and quiet, and the spin, even when slightly off-balance is quiet. The Whirlpool with even the slightest out-of-balance was noisy. Spin-Spray Only one after the wash. None for the rinses. Oh well. Spin Speed Slow ramp-up and acceptable in the normal cycles. The delicate/hand-wash cycle spin speed is too slow. I'll likely end up putting delicates through a regular spin at the end of the delicate cycle. Now, my real reason for posting...the installers tested the fill and drain, and informed me that I might hear a clicking noise the first few times the machine approaches full spin speed. As they were testing the drain it happened, a distinct CLICK.......CLICK.....CLICK...CLICK, increasing as the speed increased. They said it might happen once more, then wouldn't happen again. They were right, but I wonder why? Has anyone else experienced this? -L |
Post# 548299 , Reply# 1   10/9/2011 at 14:43 (4,583 days old) by cehalstead (Charleston, WV)   |   | |
don't know why, but mine did the same...any experts out there with an answer?? |
Post# 548337 , Reply# 2   10/9/2011 at 18:54 (4,583 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 548340 , Reply# 3   10/9/2011 at 19:09 (4,583 days old) by llmaytag (Southern California)   |   | |
Post# 548353 , Reply# 4   10/9/2011 at 20:47 (4,583 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 548386 , Reply# 5   10/9/2011 at 22:39 (4,583 days old) by llmaytag (Southern California)   |   | |
Post# 548392 , Reply# 6   10/9/2011 at 23:38 (4,582 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Peter, i never heard anything about "metal" smell being harmful... Remember we're humans, not a doll made of sugar. If we take everything too serious, we would live inside a bubble because even the purest air in the middle of a jungle also has some contaminants. |
Post# 548403 , Reply# 7   10/10/2011 at 04:12 (4,582 days old) by PeterH770 (Marietta, GA)   |   | |
It's lethal! Just a whiff and you pass out cold for 3 hours. When you wake, you may or may not still have your kidneys. And if your dryer is running next to the running washer, the vapourised metal will be sucked into the dryer and permeate your clothes. Horrible and unspeakable things happen then when you wear those things.
Open *all* windows and doors to be safe... |
Post# 548422 , Reply# 8   10/10/2011 at 06:40 (4,582 days old) by mrb627 (Buford, GA)   |   | |
I would think that if it was a flat spot on the belt you would hear it during agitation as well.
The smell may be coming from the brake system. I think they coat it with some oily substance to protect it during storage/distribution. Once it burns off, it should go away. Peter has inhaled more than his fair share of SQ metalic vapors, apparently! Malcolm |
Post# 548424 , Reply# 9   10/10/2011 at 06:58 (4,582 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Malcolm when the washer is agitating the motor is running in reverse and the idler pulley is pulled in the other direction and it does not make this sound. Remember that SQ uses the belt as the clutch as the machine drains and slowly gets up to full spin speed. The idler pulley is designed to give a lighter tension in the spin direction so it will not stall the motor on start up. |
Post# 548467 , Reply# 10   10/10/2011 at 10:34 (4,582 days old) by llmaytag (Southern California)   |   | |
Post# 548546 , Reply# 11   10/10/2011 at 17:31 (4,582 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 548558 , Reply# 12   10/10/2011 at 19:03 (4,582 days old) by cehalstead (Charleston, WV)   |   | |
but if we discuss that much further, we'll have to move it to dirty laundry. :) |
