Thread Number: 37097
Our 1990 Whirlpool Pair. |
Post# 551820 , Reply# 1   10/25/2011 at 13:22 (4,566 days old) by DirectDriveDave ()   |   | |
On both panels you can see the the Clean Touch touch pads have cracked over time, but the control themselves work 100%. |
Post# 551821 , Reply# 2   10/25/2011 at 13:23 (4,566 days old) by DirectDriveDave ()   |   | |
Tub pic. The corners of the lid need cleaning but I soon plan to get to that. |
Post# 551822 , Reply# 3   10/25/2011 at 13:24 (4,566 days old) by DirectDriveDave ()   |   | |
I love this on the lid, you don't see this today. |
Post# 551823 , Reply# 4   10/25/2011 at 13:25 (4,566 days old) by DirectDriveDave ()   |   | |
Now for the dryer! |
Post# 551824 , Reply# 5   10/25/2011 at 13:27 (4,566 days old) by DirectDriveDave ()   |   | |
Drum for the dryer, and also the washer vid on this post. Oh and for those who want to know... Washer: LA9500XTW0 Dryer LG9501XTW0 CLICK HERE TO GO TO DirectDriveDave's LINK |
Post# 551825 , Reply# 6   10/25/2011 at 13:33 (4,566 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 551827 , Reply# 7   10/25/2011 at 13:36 (4,566 days old) by DirectDriveDave ()   |   | |
From what i've seen on the manual. It goes to the lower speed the last 4 minutes of the wash for extra fabric care. I think all Whirlpool brand direct drives (with the exception of low models) did this. |
Post# 551829 , Reply# 8   10/25/2011 at 13:42 (4,566 days old) by cfz2882 (Belle Fourche,SD)   |   | |
my '97 WP DD does the wash speed shift too. |
Post# 551831 , Reply# 9   10/25/2011 at 13:43 (4,566 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 551833 , Reply# 10   10/25/2011 at 13:54 (4,566 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 551837 , Reply# 11   10/25/2011 at 14:07 (4,566 days old) by rpms (ontario canada)   |   | |
I just used an Inglis/Whirpool washer, for the first time today, with the same features and agitator. I don't get the reduced agitation, either? After 12 minutes of heavy agitation, what does the 4 minutes of reduced do? I also don't understand why the agitaor has all those vanes at the top? The water never gets that high.
I have a Kenmore with the dual action agitator. I would have to say, the Kenmore is much quieter, than the Inglis/Whirlpool. |
Post# 551839 , Reply# 12   10/25/2011 at 14:15 (4,566 days old) by joefuss1984 (Little Rock, AR)   |   | |
My Kenmore and my Whirlpool had the same agitator as this one did. I have always thought Kenmore was quieter as well. I am sure it is something do with how they do the quiet packs. I don't really understand that part either, because i never see any sound insulation. This Whirlpool is nicer than the one I had.
DD Dave - have you ever had to change the dog ears in the agitator on this? My mom's Kenmore had to have them changed about 3 or 4 times in the short 8 year time span of the washer. My Kenmore and Whirlpool that I owned never did. |
Post# 551842 , Reply# 13   10/25/2011 at 14:31 (4,566 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 551848 , Reply# 14   10/25/2011 at 15:06 (4,566 days old) by yogitunes (New Jersey)   |   | |
the step down is referred to as "Gentle Wash"......more of a SOAK than anything else, on a regular load, once the shift down, all wash action/rollover stops, even with the DA agitator........
the only reason for the top fins of the agitator is the SWIRL effect/look of the Surgilator I have never had one of these machines shred anything......and I washed good size loads......eventually I changed my DA, for the larger base version from a KitchenAid....turbulent rollover on high speed, and actual movement on gentle... |
Post# 551871 , Reply# 17   10/25/2011 at 17:45 (4,566 days old) by yogitunes (New Jersey)   |   | |
in actuality, the larger base agitator was for any 2 or 3 speed agitation, as long as the 2 lowest ones were used for agitation, any speed for spin.......
I put this in any machine I use......even in high speed, although some argue about strain on the tranny, but never had that issue, but there is no difference between Kenmore, Whirlpool, KitchenAid, all the same underneath, one tranny for all... if you ever come across one, fill your machine with just water, and run the machine on high speed agitation, switching out the agitators back and forth.... you will be suprised at the tidal wave...... |
Post# 551884 , Reply# 18   10/25/2011 at 19:14 (4,566 days old) by DirectDriveDave ()   |   | |
whirlcool: That's not the transmission, that is probably a problem with your motor or maybe your control board. yogitunes: that's pretty interesting to know. Is your KA agitator one of those cool green ones? |
Post# 551902 , Reply# 19   10/25/2011 at 20:44 (4,566 days old) by yogitunes (New Jersey)   |   | |
Post# 551904 , Reply# 20   10/25/2011 at 21:15 (4,566 days old) by DirectDriveDave ()   |   | |
ahh, cool deal. One thing I always did love was that metallic finished fabric softener dispenser! |
Post# 551950 , Reply# 22   10/26/2011 at 05:42 (4,566 days old) by DADoES (TX, U.S. of A.)   |   | |
Allen, the motor is 2-speed. The transmission has nothing to do with speeds, either agitation or spin. It's not a clutch system like GE. Speed is determined via the motor RPM. You have an electrical problem somewhere with getting power to the low-speed winding of the motor (or a bad motor), not a mechanical problem. |
Post# 551981 , Reply# 23   10/26/2011 at 08:59 (4,566 days old) by DirectDriveDave ()   |   | |
whirlcool, the motor we have is 3-speed. If you check out this site here, that should have many necessary parts when you put in your model number. CLICK HERE TO GO TO DirectDriveDave's LINK |
Post# 552107 , Reply# 24   10/26/2011 at 18:58 (4,565 days old) by yogitunes (New Jersey)   |   | |
heres a youtube video of the larger agitator in action......
many thanks to DADoES for filming and posting it...... CLICK HERE TO GO TO yogitunes's LINK |
Post# 552109 , Reply# 25   10/26/2011 at 19:06 (4,565 days old) by DirectDriveDave ()   |   | |
ahh yeah, I have seen that vid many times! Now I know that is the top speed for a KitchenAid machine, but (just so i'm not confused) were you saying you also had this agitator performing with Whirlpool's top speed? |
Post# 552112 , Reply# 26   10/26/2011 at 19:27 (4,565 days old) by yogitunes (New Jersey)   |   | |
YES.....actually I used it in a Kenmore Limited with a 3 speed.....always on the HeavyDuty cycle, fast wash and spin.....the smaller fin DAplus didn't seem to move the load the way I wanted it to......and on gentle, nothing moved, unless you loaded the machine 1/3 with clothes on a full water level....
in the newer models of Kenmores, Normal was medium speed with a fast spin....this agitator was perfect for that, and quieted the machine down to nothing.... |
Post# 552113 , Reply# 27   10/26/2011 at 19:34 (4,565 days old) by DirectDriveDave ()   |   | |
cool deal man. How available are those KA agitators though? (just curious) |
Post# 552120 , Reply# 28   10/26/2011 at 20:17 (4,565 days old) by yogitunes (New Jersey)   |   | |
Post# 552122 , Reply# 29   10/26/2011 at 20:37 (4,565 days old) by DirectDriveDave ()   |   | |
Nice, i'll take a peek when interested. Thanks! |
Post# 552124 , Reply# 30   10/26/2011 at 20:49 (4,565 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 552137 , Reply# 31   10/26/2011 at 22:24 (4,565 days old) by appnut (TX)   |   | |
Post# 552216 , Reply# 32   10/27/2011 at 09:06 (4,565 days old) by DirectDriveDave ()   |   | |
lol, did they actually make them in that color? |
Post# 552218 , Reply# 33   10/27/2011 at 09:15 (4,565 days old) by yogitunes (New Jersey)   |   | |
I don't think they ever came in pink.........I just like the white on white on white.....seems so clean and crisp.......
MrEric has an added splash shield to his KitchenAid, transferred from a Calypso, a nice trim addition.....wonder if I can talk him into posting a pic of it.... not to mention he has the matching dryer with the oven door window, and interior light that comes on during use.......could not imagine this machine without it just wish these machines came with a top work light.... we like little upgrades.... Thanks DADoES for the part numbers, I may want to order a full white one for the heck of it..... |
Post# 552264 , Reply# 34   10/27/2011 at 13:38 (4,564 days old) by yogitunes (New Jersey)   |   | |
Post# 552274 , Reply# 35   10/27/2011 at 14:31 (4,564 days old) by DirectDriveDave ()   |   | |
wow, that's awesome! |
Post# 552290 , Reply# 36   10/27/2011 at 15:28 (4,564 days old) by mickeyd (Hamburg NY)   |   | |
Here's an old early mornin' video of the Big AQUA (that's for you Bob) Kitchen Aid agitator in a Whirlpool on high speed. It is pretty fast. Enjoy. Please excuse the Maytag Wringer interruption. CLICK HERE TO GO TO mickeyd's LINK |
Post# 552295 , Reply# 37   10/27/2011 at 15:55 (4,564 days old) by KenmoreBD (Mass, usa )   |   | |
The folks had a lower end 2 speed with black tub from 88/89, that was a great washer took abuse and never quit. Still have the dryer, washer rusted out in 02. |
Post# 552344 , Reply# 38   10/27/2011 at 22:41 (4,564 days old) by DirectDriveDave ()   |   | |
Micky, that was one of the very first washer vids I ever saw on youtube, I still enjoy watching it! |
Post# 552347 , Reply# 39   10/27/2011 at 23:35 (4,564 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Whatever you do keep these machines going. No DD Whirlpool/Kenmores are being made now. I've heard from several sources that the new PSC belt drive is not near as good. Besides great durability and wash performance the styling of these machines is timeless. These come from a great series of machines and are pretty near TOL(only the Whirlpool Imperial, Lady Kenmore, Kenmore LTD. and KitchenAid Superba had more options that I know of) in WP's lineup. This pic shows WP's top machine in 1986 the all Electronic Kenmore LTD. These were produced up through the late 90's
Post# 552416 , Reply# 41   10/28/2011 at 10:39 (4,564 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 552419 , Reply# 42   10/28/2011 at 10:56 (4,564 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 552421 , Reply# 43   10/28/2011 at 11:13 (4,564 days old) by mickeyd (Hamburg NY)   |   | |
John, those thin twins are so much fun and versatile. The place where I stay in Pompano has them, so sturdy, many sets almost 10 years old and issue free.
How cool, Dave: first movie you've seen and first one I ever made. Wish I knew hoe to chop it up so I could put the Easy Spin section in Dick's or Pete's thread. What's your Youtube name so I can watch your WP movies? |
Post# 552423 , Reply# 44   10/28/2011 at 11:15 (4,564 days old) by DirectDriveDave ()   |   | |
I do believe you can see that in a youtube video if you search for it, I cannot remember the exact name for it, but it will show you some stuff. |
Post# 552424 , Reply# 45   10/28/2011 at 11:18 (4,564 days old) by DirectDriveDave ()   |   | |
pardon the double post but I cant edit posts since I am a standard member. oh those are your vids? cool to know! :D Here is my youtube :) CLICK HERE TO GO TO DirectDriveDave's LINK |
Post# 552435 , Reply# 46   10/28/2011 at 12:59 (4,563 days old) by yogitunes (New Jersey)   |   | |
Nice videos Dave........but one question on the ejection pump......is your drain hose piped directly into it?........
I have a sewage ejector underground for the bathroom in the basement, of which the washers drain into that, but I MUST have a laundry tub and a filter screen on the drain hoses, as per the instructions, not so much about the lint, but any strings that may wrap around and jam the the impeller...... just worried for you, should you not be home, and this jams.....you would have a serious flood..... |
Post# 552439 , Reply# 47   10/28/2011 at 13:38 (4,563 days old) by DirectDriveDave ()   |   | |
We did think about that. From what I saw on the box, it does NOT require screens. I myself did think exactly about what you had just said, but yeah, it hasnt had any problems. |
Post# 552780 , Reply# 51   10/30/2011 at 10:47 (4,562 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 552861 , Reply# 52   10/30/2011 at 19:39 (4,561 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
Post# 552862 , Reply# 53   10/30/2011 at 19:41 (4,561 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
Post# 552863 , Reply# 54   10/30/2011 at 19:45 (4,561 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
The turquoise agi helps me to get over the lack of my old A806, and the set is delightful and quiet and does a spectacular job. I only feel a little bit bat about the oven door not being in a place where it can be enjoyed, but I have plans... this set will move with me to my next home and I hope to be able to give them a spot where they can be seen.
Now, to find the washer a Superba control panel... |
Post# 552864 , Reply# 55   10/30/2011 at 19:52 (4,561 days old) by DirectDriveDave ()   |   | |
the dryer light is on when it runs too? that's pretty cool! |
Post# 1063002 , Reply# 56   3/12/2020 at 18:15 (1,505 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
When did whirlpool come out with the clean touch design? What were the cycles and buttons? What did they do? |
Post# 1063007 , Reply# 57   3/12/2020 at 19:28 (1,505 days old) by Yogitunes (New Jersey)   |   | |
