Thread Number: 37206
Belts for portable TT |
Post# 553344   11/1/2011 at 11:27 (4,559 days old) by yogitunes (New Jersey)   |   | |
Post# 553356 , Reply# 1   11/1/2011 at 12:54 (4,559 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 553366 , Reply# 2   11/1/2011 at 13:18 (4,559 days old) by mr-maytag (Minneapolis, MN)   |   | |
Post# 553368 , Reply# 3   11/1/2011 at 13:28 (4,559 days old) by yogitunes (New Jersey)   |   | |
my fault......I'm not thinking....yes the poly belt for the impellors.....
snapped clean where they were joined..... and a Thankyou to MrMaytag....I may have a new one.... what a cool machine to operate Tim...... I have the A50 and a Hoover TT...... the hoovers drain hose has a kink where it comes out of the back, I will either put a clamp to keep it open, or slice that part out and make a reconnection...a small slinky may slide over it also to prevent this from happenning... |
Post# 553375 , Reply# 5   11/1/2011 at 13:57 (4,559 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 553381 , Reply# 6   11/1/2011 at 14:24 (4,559 days old) by yogitunes (New Jersey)   |   | |
Post# 553382 , Reply# 7   11/1/2011 at 14:29 (4,559 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 553383 , Reply# 8   11/1/2011 at 14:35 (4,559 days old) by mr-maytag (Minneapolis, MN)   |   | |
Post# 553423 , Reply# 9   11/1/2011 at 17:36 (4,559 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You can just drill another hole in the pot-metal pulley 90 degrees from the first and use a new roll-pin. The polly belts are heat welded together so you can try to re-weld it or if you find a replacement that is too large you can cut it down and re-weld it. You can always buy two MT DW belts and make one for the porta-washer or use two WP dryer blower belts, both of these are still available. |
Post# 553445 , Reply# 10   11/1/2011 at 18:36 (4,559 days old) by mr-maytag (Minneapolis, MN)   |   | |
Post# 553454 , Reply# 11   11/1/2011 at 19:01 (4,559 days old) by yogitunes (New Jersey)   |   | |
Post# 553461 , Reply# 12   11/1/2011 at 19:15 (4,559 days old) by cfz2882 (Belle Fourche,SD)   |   | |
a heated knife should work good too. |
Post# 553468 , Reply# 13   11/1/2011 at 20:17 (4,559 days old) by mr-maytag (Minneapolis, MN)   |   | |
Post# 553883 , Reply# 14   11/3/2011 at 15:46 (4,557 days old) by yogitunes (New Jersey)   |   | |
Post# 553918 , Reply# 15   11/3/2011 at 16:08 (4,557 days old) by yogitunes (New Jersey)   |   | |
found one.....another parts place......Bell Parts Supply
thanks for you help guys CLICK HERE TO GO TO yogitunes's LINK |
Post# 553934 , Reply# 16   11/3/2011 at 17:21 (4,557 days old) by yogitunes (New Jersey)   |   | |
Post# 553965 , Reply# 17   11/3/2011 at 19:45 (4,557 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Martin I don't think it would be too difficult to use a 3/8" wide V belt for this purpose if you change the motor pulley, you could use a MT HOH motor pulley and you would need to add a spring loaded idler pulley from a clothes dryer to maintain proper belt tension. This is the way this machine and the MT belt drive DW should have been built in the first place, but MT was trying to control cost on both these appliances and took the cheap way out. |
Post# 553968 , Reply# 18   11/3/2011 at 20:11 (4,557 days old) by yogitunes (New Jersey)   |   | |
Post# 554087 , Reply# 19   11/4/2011 at 13:33 (4,556 days old) by yogitunes (New Jersey)   |   | |
Post# 554089 , Reply# 20   11/4/2011 at 13:43 (4,556 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 554091 , Reply# 21   11/4/2011 at 13:54 (4,556 days old) by yogitunes (New Jersey)   |   | |
Its simple windshield washer hose I had in the garage....I had black also, but thought the orange added color......can get this at most any auto parts store.....it pays to have a brother who works at PepBoys.......
I measured the hose out to what would fit around all the pulleys, and then cut it off about an inch shorter, for a little tension, and then used a smaller piece to join and hold the ends together with super glue, just be cautious of the insert not too big to cause a lump, but yet flexible enough to work with the tube in action.... I think I am gonna make one also for the hoover.....it seems really floppy as well.... |
Post# 554139 , Reply# 22   11/4/2011 at 19:50 (4,556 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Love the orange color. It's a real standout. It very clearly shows how the belt runs through the machine. |
Post# 554148 , Reply# 23   11/4/2011 at 20:34 (4,555 days old) by yogitunes (New Jersey)   |   | |
Tim
the new belts, both on the Maytag and the Hoover, has really made the machines kick ass at washing and tumbling the clothes...especially the Hoover, should be used with the lid closed, it is really churning me water......reminds me of the first one I ever had.... the old one on the hoover was really floppy and stretched....would turn the clothes, but at a slow pace, obviously from the excessive slippage...... try a new one on yours......just to see if you have any difference.... |
Post# 554170 , Reply# 24   11/4/2011 at 22:45 (4,555 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 554224 , Reply# 25   11/5/2011 at 08:28 (4,555 days old) by yogitunes (New Jersey)   |   | |
Eddie....don't sweat it......this is to be expected in our collections....
these are still nice machines, and they do function well......belts snap, hoses break......they are 40 years old.....it happens! on the Maytag, I got 2 complete loads done, went for the third, and then it snapped........tried to fix the old one, or purchase a new one....no luck so I reserved to make one, and it works, at the same time, may helps others for when it happens...... on the Hoover, it has a kinked drain hose, they ALL have this happen out the rear of the machine......all I did was cut out the kinked area, inserted a fitting, 2 clamps, and I am back in action......this one also has a stretched out wash belt, and I repaired it the same way....... these machines now kick ass in washing......and you have to love that spinner! I now can't decide where to display them....so many options! |
