Thread Number: 37289
My Servis 308S is here! |
Post# 554500   11/6/2011 at 10:02 (4,555 days old) by servisslimline (England, Brighton & Hove)   |   | |
hi you lot, the servis is now safe in the house, it is in very good condition but there are a few problems
1) the plug has been taken off 2) the doorseal needs replacing 3) one of the drum paddles are missing, if anyone can find one anywhere id be greatful ill be ordering a new seal next week along and ill fit a new plug and start having a bit of fun with it. pictures are on the way :) |
Post# 554510 , Reply# 1   11/6/2011 at 10:42 (4,554 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 554512 , Reply# 2   11/6/2011 at 10:44 (4,554 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 554513 , Reply# 3   11/6/2011 at 10:45 (4,554 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 554514 , Reply# 4   11/6/2011 at 10:47 (4,554 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 554515 , Reply# 5   11/6/2011 at 10:48 (4,554 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 554517 , Reply# 6   11/6/2011 at 10:49 (4,554 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 554522 , Reply# 7   11/6/2011 at 11:12 (4,554 days old) by boschlover1997 ()   |   | |
lovely machine phil, what drum capacity does it have? |
Post# 554524 , Reply# 8   11/6/2011 at 11:32 (4,554 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 554525 , Reply# 9   11/6/2011 at 11:36 (4,554 days old) by hoovermatic (UK)   |   | |
Those programmes are wonderfully evocative of days gone by - Orlon, Nylon, Tricel, Acrilan! Wonderful :-) |
Post# 554538 , Reply# 10   11/6/2011 at 13:17 (4,554 days old) by paulc (Edinburgh, Scotland)   |   | |
Post# 554558 , Reply# 11   11/6/2011 at 15:08 (4,554 days old) by ronhic (Canberra, Australia)   |   | |
Post# 555908 , Reply# 12   11/11/2011 at 10:59 (4,549 days old) by servisslimline (England, Brighton & Hove)   |   | |
ok, the machine now has a plug on, ive briefly tried a spin, not a full spin though, sounds excellent, now all i need is a doorseal which i should be ordering this weekend and a paddle which i am trying to sort, should be usable by xmas at the latest, the machine is alot quieter than i first thought as i was thinking it would be almost as load as the hotpoint but its nowhere near as loud, even with the lid off and in a very echoey hallway.
phil |
Post# 556074 , Reply# 13   11/12/2011 at 05:51 (4,549 days old) by servisslimline (England, Brighton & Hove)   |   | |
i noticed matchbox paul said something about the spin speed being 850/460
i was looking in my servis 310 manual last night to get an idea of what the machine will do and noticed the 310 has 3 spin speeds not including drip dry, those being 1000/600/460, 600 being interm spins and 460 being wollen spin, im just wondering if the 308s will have a 3rd speed being that 600rpm interm spin? phil |
Post# 556078 , Reply# 14   11/12/2011 at 06:43 (4,549 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Great find Phil, they are a perfect sturdy mechanical washer, seperate base to which the struts are attached, you can remove the cabinet and the drum stands on its rigid base, the vitreous inner & outer tubs are perfectly balanced and help OOB situations, my Mum had the 308 as her first auto and it served six of us well until the arrival of the Quartz 6033 ...
The spin speeds are 850 / 460 and drip dry...I love the ratchet sound of the timer which has a long arm with the timer at the back as we can see...Door Boots and motors are around to be found, the drum baffle is a problem , you will have to find a scrap machine, this was about the only week spot on these machines, if the screw bolt failed you lost the paddle - the issue is you have to take the drum apart to bolt it back on from the underside of the inner tub, I would advise not using it until sorted as it will / can cause uneven drum movements, all these drums try to balance the clothes (especially on spin) by distributing clothes into the three segments made by the baffles, if one is missing it bunches the clothes up!! It looks in great shape and very clean, look after it and it will give you years of Servis Service.. |
Post# 556277 , Reply# 15   11/13/2011 at 11:07 (4,547 days old) by servisslimline (England, Brighton & Hove)   |   | |
