Thread Number: 37758
Trying to figure out capacity.... |
Post# 561685 , Reply# 1   12/7/2011 at 09:34 (4,523 days old) by westie2 ()   |   | |
These were 18 pound rated. The slower spin speed could mean a new belt is needed or the speed clutch is on slow. These were good machines. |
Post# 561687 , Reply# 3   12/7/2011 at 09:46 (4,523 days old) by yogitunes (New Jersey)   |   | |
Post# 561696 , Reply# 5   12/7/2011 at 11:20 (4,523 days old) by yogitunes (New Jersey)   |   | |
well, outside of the normal safety issues, unplug unit......take back panel off, in the lower left you will see the motor/clutch/pump assembly......first lets check the belt for wear or damage........
next you want to make sure the clutch is operating smooth, keeping fingers cleared, you want to put the machine into spin, and your checking for any unusal sounds, clunking, rattling.....but mainly your checking for the solenoid, connected to the motor base plate, and theres a little arm that when engaged causes the slow speed(up position).......for high speed, make sure this little arm is not holding the little legs sticking out from under the clutch, it could be bent also....for the most part everything should be smooth........ I am working on a GE version right now.....with a chopped up belt, and causing the slipping.......but for fun, and just a little more kick in the agitation and higher spin speed, I am going to install a wider belt.....also this little arm on mine is bent out of the way...a simple fix lets get your washer going first......and then move onto the dryer.....its just basic maintenance to clean out, and check the belt and idlers for wear.....real simple to dis-assemble.... let us know how you make out, and if you need further help....... theres also the possibility of converting this to the true filter flo.....you'll be amazed at what lint it can remove from your wash versus the rim-flo |
Post# 561709 , Reply# 6   12/7/2011 at 12:39 (4,523 days old) by geeve420 ()   |   | |
Thanks again, I will give it a go and report back! Geeve |
Post# 561710 , Reply# 7   12/7/2011 at 13:14 (4,523 days old) by macboy91si (Frankfort, KY)   |   | |
LOL I though I recognized that machine! This machine is no more, she's a GE Spotscrubber now and yes I believe the 2.8 is correct. Hopefully you can repair the machines and keep them, they are pretty durable. Your slipping issue could be the best or the clutch. These machines employed a 2-speed clutch which can be fickle. As Yogi said, a few simple checks and you should have a solution. I too would be willing to bet the machine is running in slow speed, I've had fits out of that speed solenoid before with it getting stuck. You should be able to watch the machine agitate to see if it's going slow. If the machine is agitating slow and spinning slow evenly and not making any strange squeaking or grinding/clicking then I would suspect the clutch solenoid. |
Post# 561718 , Reply# 10   12/7/2011 at 13:51 (4,523 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It is very rare for the clutch to get stuck in low speed, usually the reverse is the case when the shifter fork gets broken off and you get only hi speed. You can easily test this by starting the washer on low speed agitation, let it run for say two minutes then WITH the machine agitating switch to normal speed and see if it kicks in to a higher speed agitation within one minute. [ it does not hurt GE- HP washers to change the speed while they are running, GE would not have built a machine that could be so easily damaged, and anyone who wants to can come to our museum and flip the speed switch back and forth all day long on one of our several GE washers may do so if they like ]
Most likely a poor spin is caused by a very worn or loose belt, worn out clutch or a problem with suds-locking or other pump-out problems.
Martin putting a wider belt on your washer will not increase the spin speed as it will behave the same way on both pulleys. |
Post# 561774 , Reply# 12   12/7/2011 at 18:53 (4,523 days old) by yogitunes (New Jersey)   |   | |
Keep us posted on what you find.......
John....thanks for the info...I was thinking about the clutch issue with the wider belt, for agitation the single speed clutch may prove to show a difference, but thats about it.......Now on the Whirlpool, with the belt direct to agitation pulley, there is improvement, not as much as I wanted, but still a nice kick up on speed... |
Post# 561898 , Reply# 13   12/8/2011 at 08:01 (4,522 days old) by macboy91si (Frankfort, KY)   |   | |
Actually come to think of it, I ended up having to take the selection switch off and clean it... Not suggesting that may be your issue, but that's what happened to be. My previous motor/clutch was missing the finger that engages low so it only had high speed. After I replaced the motor during the Spotscrubber conversion, I noticed the machine had only low speed, after much tinkering with the speed solenoid I found out that the issue was electrical and it was the push-button bank for the speeds that was gummy. The belt sounds like a reasonable and Combo52 (John) knows his stuff. Personally I had always heard that changing speeds while running will break the speed changer fingers but I've done this several times and aside from a few clicks, nothing bad so far. My machine needs a new belt and I need to obtain a spare transmission at some point.
Good luck, just tak it one step at a time, start with smallest things and work up, belt would be pretty easy to check.
-Tim |
Post# 561906 , Reply# 14   12/8/2011 at 08:45 (4,522 days old) by bajaespuma (Connecticut)   |   | |
The difference between GE/Hotpoint "Extra-large capacity" and "Large Capacity" (what a joke) amounts to barely three extra inches of water within the same diameter tub. I've actually weighed what I considered to be the maximum amount of dry laundry that could/should go into these tubs and Consumer Reports is sadly very correct when it has stated through the years that most of these old top-loaders could only handle 8 lbs. of normal fabrics. The extra room in the big GE's might give you enough room to handle 10 lbs. of fabrics. If you overload on a GE, unlike on a Maytag, the machine will still go on its merry way through all the agitation and spin, but you won't get any rollover (especially if there's a straight-vane activator in there) and performance will suffer. I think the most capacious top-loaders were always the big Whirlpools and the 1-18's.
By comparison, sorry y'all, my LG front loader can handle 20 lbs. of laundry easily. |
