Thread Number: 378
adjusting water level in NEW F/L's |
Post# 47819 , Reply# 1   10/25/2004 at 23:41 (7,122 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
I'd be very leary of adjusting the water level beyond the factory setting on any front loader. Every thing was designed to give performance with certian water levels. Change the water levels and many other things may change also. Also by opening the washer and tampering with settings without permission can invalidate any warranty. It is one thing if a factory certifed tech comes to your home and determines the washer is not taking on the required amount of water and adjusts the settings. It is another matter all together if you take it upon yourself to do this. The Frigidaire change involved adjusting the fill pressure switch, IIRC and was not something one would find in the user's manual. Rather someone came upon it and posted his findings on THS. Launderess |
