Thread Number: 37862
Maytag A50 |
Post# 563093   12/13/2011 at 21:24 (4,518 days old) by mr-maytag (Minneapolis, MN)   |   | |
Post# 563094 , Reply# 1   12/13/2011 at 21:38 (4,518 days old) by yogitunes (New Jersey)   |   | |
Post# 563095 , Reply# 2   12/13/2011 at 21:46 (4,518 days old) by mr-maytag (Minneapolis, MN)   |   | |
Post# 563098 , Reply# 3   12/13/2011 at 22:05 (4,517 days old) by yogitunes (New Jersey)   |   | |
I am doing great with them....better with the Maytag than the Hoover, and by that I mean the Hoover now kicks ass, and you have to leave the lid closed while in use.......by design the Maytag has the little horizontal shield which keeps the water in a tidal wave.......
yes, I used windshield washer hose, a small piece of hard tubing used for vacuum lines of a car, and a dab of superglue......this is under a little more tension than the original flopping around, and it does give a nice vigorous wash, too loose and it will flop off the pulleys.......I was also thinking of using air line for an aquarium, a bit smaller in diameter to fit lower into the pulley...... but otherwise, I have been running them a few times a week, and so far no problems.....an inexpensive fix for the most part, but remember to measure with the new hose, and then take off about 1 - 2 inches to create a tension... let me know how you made out......if you can't find parts, I can send you some |
Post# 563124 , Reply# 6   12/14/2011 at 00:40 (4,517 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
I think the reason there is no "Buy It Now" button is because it is an old auction, not currently in effect(2009). That's probably also why it didn't come up in a search. I'd contact the seller directly and ask it they have any left. |
Post# 563162 , Reply# 7   12/14/2011 at 08:13 (4,517 days old) by yogitunes (New Jersey)   |   | |
Post# 563185 , Reply# 8   12/14/2011 at 09:57 (4,517 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 563230 , Reply# 9   12/14/2011 at 12:34 (4,517 days old) by mr-maytag (Minneapolis, MN)   |   | |
No kidding, Tim. I got a NOS belt for my avocado A50 in Early, Iowa and it broke the first time I used it - it was too old. Then I got what I assume was almost the last (or the very last) belt in stock from pcappliancerepair.com last spring...it's been good. Now I need one for this new acquisition. ;)
