Thread Number: 37922
Help needed diagnosing a Frigidaire FL set |
Post# 563834   12/18/2011 at 01:52 (4,512 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Greetings fellow washer people! A friend of mine called me about his 2001 Frigidaire front load set, asking for help. I went over this afternoon to check them out and this is what I discovered.
1. The washer. It has a timer issue, as in the timer sticks or freezes during the cycle. Obviously this causes it to stay in (whatever) operation for extended periods of time. It does not appear to be the "same spot" every time as he says it will eventually complete the 35 minute cycle, but can take 2 hours or more to do so.
My question is, can the motor on a timer like this (see the next photo) be removed / cleaned / repaired, or must the entire timer be replaced?
2. The gas dryer. The dryer has two issues: A) When turning the timer knob to any cycle in prep to start it, I can hear one of the gas valve solenoids "click". This is WITHOUT the dryer running yet. If I have the temp selector set to "air fluff" it of course does not "click". B) As dryer is running, if the door is opened, the interior light comes on but it does NOT stop, it continues running! I press and release the door switch to make sure it's still working properly and the light goes on and off, but the dryer continues to run.
Obviously something is getting power somewhere to make the valve click and keep it running when the door is opened, my question is where do I start looking?
Post# 563835 , Reply# 1   12/18/2011 at 01:54 (4,512 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 563836 , Reply# 2   12/18/2011 at 01:56 (4,512 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 564188 , Reply# 3   12/19/2011 at 22:56 (4,510 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 564204 , Reply# 4   12/20/2011 at 01:38 (4,510 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hi John, The water, hot, warm and cold are flowing as it should, no reduction in flow at all. The washer fills to normal levels in an average, but normal amount of time (I have the same type of washer, tho front controls). I could hear the timer motor at times running, but other times, nothing at all and that was not during a fill. It filled and was washing and washing and washing. I had to move the timer manually. Then it was draining and flushing and that kept going too until I advanced the timer manually. Kevin |
Post# 564206 , Reply# 5   12/20/2011 at 01:48 (4,510 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 564241 , Reply# 6   12/20/2011 at 08:16 (4,510 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 564306 , Reply# 7   12/20/2011 at 14:51 (4,510 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 564362 , Reply# 8   12/20/2011 at 18:32 (4,510 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 564420 , Reply# 9   12/21/2011 at 00:11 (4,509 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 567412 , Reply# 11   1/6/2012 at 16:04 (4,493 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
The washer: I replaced the timer last night and started a load of wash as I was buttoning it up and started working on the dryer. It ran thru the wash portion of the cycle as it's supposed to, then drained to spin but that was it. No tumble, no spin. I tried resetting the timer to the final spin and other then the pump running, nothing. After watching and fiddling with it for about 10 minutes, the owner (my friend) then said he can reset it to spin on another cycle and it will. So I reset the timer to the "perm-press" cycle final spin. After about 5 minutes of "1 rotation, 30 sec pause, 1 rotation, 30 sec pause, it FINALLY worked its way into a spin. However, when it was supposed to the "high rpm spin" for the last 4 minutes, the drum just coasted to a stop and sat there with the drain pump running the whole time.
What do you think, bad motor controller??
On to the dryer: I replaced the door switch, but when I tested it by opening the door while running, it still kept running. DAMN! Not the door switch.
Any more thoughts on these issues?
Thanks much! Kevin |
Post# 567516 , Reply# 12   1/6/2012 at 23:49 (4,492 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 567535 , Reply# 13   1/7/2012 at 02:17 (4,492 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
My Miele began doing something similar about a year ago now, thus only spins at 900rpms.
Basically machine will spin fine when set to 900rpms, but if switched to 1100rpms the drum coasts to a stop and all one hears is the sound of the motor running. Have had several Miele repairmen troop though my laundry area all with various ideas as what *might* be wrong but no certain repair. One man was able to get the machine to start high speed spinning by reaching into the washer where the motor is located and shimmy some wires about. However as the washer is very heavy and much of that is the cast iron motor he nor anyone since is willing to do what is required. Get at the motor and start tracing wires back to the control board to see if there is short, broken wire, or something wrong along those lines. Based upon what one has read online about similar Miele issues it could be the control/mother board, or the motor. A new motor is $1500/USD plus labor and may *not* solve the problem. A new motherboard is about $400/USD and again may not solve the problem either. I'd hunt down a schematic and work tracing the wires. Baring that see if you can scrounge up a used but known to be working control board for a swap. Just me for you, do with the information what you wish. |
Post# 567686 , Reply# 14   1/7/2012 at 18:18 (4,492 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
After it was all back together and turned around again, we ran a load of laundry thru it and it worked perfectly! YAY!
However not sure how long it's going to last tho.... It looks as if the main seal has been leaking a little and the tub bearings are making some noise. It's not too bad yet, but eventually... it's only going to get worse.
Now I have to figure out where the short is in the dryer that keeps it to keep running after the door is opened!
Kevin |
