Thread Number: 38203
Maytag WU600 Series 3 Questions |
Post# 567214 , Reply# 1   1/5/2012 at 22:37 (4,494 days old) by RockBass1979 ()   |   | |
the gasket... |
Post# 567215 , Reply# 2   1/5/2012 at 22:39 (4,494 days old) by RockBass1979 ()   |   | |
the serial plate |
Post# 567216 , Reply# 3   1/5/2012 at 22:40 (4,494 days old) by RockBass1979 ()   |   | |
the inside |
Post# 567217 , Reply# 4   1/5/2012 at 22:42 (4,494 days old) by RockBass1979 ()   |   | |
So do I need a new gasket? Or is there anything I can lube, tighten or clean to help her seal better? Hell if there's any preventative matnance that anyone can suggest I would appreciate it. |
Post# 567253 , Reply# 5   1/6/2012 at 05:06 (4,494 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 569335 , Reply# 6   1/15/2012 at 18:09 (4,484 days old) by Electronicontrl (Grand Rapids, MI)   |   | |
Post# 569337 , Reply# 7   1/15/2012 at 18:09 (4,484 days old) by Electronicontrl (Grand Rapids, MI)   |   | |
Post# 569471 , Reply# 8   1/16/2012 at 07:39 (4,484 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
That gasket looks fine [ it could have the mildew cleaned off ] , but if the DW leaks at the front corners the first thing to do is tighten the tension on the door lock assembly a little [ it is adjustable, get a copy of the repair manual to see exactly how ]. Also be sure that the DW is level, differently not slanted forward and check the machine at various times during the wash cycle to make sure that it is not foaming at all as this will cause almost any DW to leak a little, Good Luck with this classic DW. |
