Thread Number: 38230
Newer Maytag smell |
Post# 567594   1/7/2012 at 09:22 (4,493 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 567600 , Reply# 1   1/7/2012 at 09:45 (4,493 days old) by westie2 ()   |   | |
Could it be gunk build up in the outer tub? Or even a small cloth in the outer tub? Or something caught under the agitator. |
Post# 567602 , Reply# 2   1/7/2012 at 09:49 (4,493 days old) by LLMaytag (Southern California)   |   | |
Post# 567605 , Reply# 3   1/7/2012 at 09:57 (4,493 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Kenny -
Check and see if the machine itself smells inside. I agree with Westie2 that there may be gunk build-up on the outer tub. If your wife uses a lot of cold or cool washing this time of year, and especially liquid softener, there could be 'slime' building up on the sides of the outer tub. I've been told that liquid detergent can add to this as well. I think we at least partially have non-phosphate formulations to thank for this. If you want to dissassemble the machine a bit, you can verify that. Once not long ago I had to use half a roll of paper towel to wipe the literal POUND of slime off the sides of the outer tub of a large cap Kenmore BD which had been used with cold water, inexpensive liquid detergent, and softener. The slime was musty sour smelling, it was nearly black, and had the consistency of mayonaise. GROSS. Several fills with hot water and bleach got rid of what I didn't wipe off, but the black water was unspeakable while it agitated. I had been telling the owners not to wash in tap cold water in the winter...they wouldn't listen...now it's warm or hot all the time for them as the dirty bleach water convinced them. If you don't want to take the machine apart, try TIDE Washing Machine cleaner - I hear it's pretty potent and effective. Gordon |
Post# 567654 , Reply# 5   1/7/2012 at 15:45 (4,493 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 567672 , Reply# 6   1/7/2012 at 16:33 (4,493 days old) by ronhic (Canberra, Australia)   |   | |
No bleach. Bleach will kill off any enzyme action in either the washing powder or dishwasher detergent and will not actually 'clean the gunk' or help loosen it.
Fill the machine with as hot a water as you can - there's no point only cleaning the bottom half of the tub!
Add a couple of kettles of boiling water too if your hot water service line to the machine can't be 'bled' first.
Add a double dose of detergent or a cup of dishwasher detergent - don't add bleach!
Let it agitate for a couple of minutes and then let it soak for at least 1/2 hour.
Let the machine finish the cycle.
Now, if you wish to, run this again but with bleach and no soak. The bleach will now be able to work properly.
Post# 567962 , Reply# 8   1/8/2012 at 21:04 (4,492 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
When MT went to the bigger tub opening, separate fill flume and redesigned plastic encased balance ring this problem of stinky washers started to occur much more often for MT. The good news is that the problem that earlier helical drive MTs had of redepositing lint and scum on the clothing as the water was being spun out was largely solved by the new balance ring, and the problem of leaking inlet air-gaps was also solved by the new fill flume.
As with any design you win some and lose some LOL. |
Post# 568102 , Reply# 9   1/9/2012 at 17:40 (4,491 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 568111 , Reply# 10   1/9/2012 at 18:35 (4,491 days old) by Frigilux (The Minnesota Prairie)   |   | |
Kenny--
When I first saw the title of this thread, I thought you meant your Maytag was new and had a 'new car smell'. Turns out the opposite was true! I use Tide Washing Machine Cleaner in my front-loader, but I think you're on the right track with the dishwasher detergent. Best of luck, and let us know if the recommended cures work for you. |
Post# 568148 , Reply# 11   1/9/2012 at 21:00 (4,491 days old) by cphifer5115 (Jackson, TN)   |   | |
i would try the washing machine cleaners out there instead of the DW detergent. someone once told me that DW detergent will eat away at the enamal coating on the tub that is if you have a metal tub. as mentioned above inthe previous post tide washing machine cleaner can be used in a regular top load washer just run the longest cycle on hot water with out any clothes in the machine and fill it full of water.
