Thread Number: 38302
LAT9605 |
Post# 568545   1/11/2012 at 19:58 (4,488 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 568836 , Reply# 1   1/13/2012 at 19:56 (4,486 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 568837 , Reply# 2   1/13/2012 at 19:57 (4,486 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 568838 , Reply# 3   1/13/2012 at 19:57 (4,486 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 568839 , Reply# 4   1/13/2012 at 19:58 (4,486 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 568840 , Reply# 5   1/13/2012 at 19:59 (4,486 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 568841 , Reply# 6   1/13/2012 at 20:00 (4,486 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 568842 , Reply# 7   1/13/2012 at 20:01 (4,486 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 568843 , Reply# 8   1/13/2012 at 20:09 (4,486 days old) by joefuss1984 (Little Rock, AR)   |   | |
So this is Myrtle the Maytag. I loved this style of Maytag washer and mammaw bought one similar in 1995. But i really like the faster agitation of the newer newton maytags. She agitates just fine and has great output during spin out. This brings us to the questions.
I had to spin the water out into a mop bucket as I am working out my garage at the moment. I noticed quite a bit of rust in the bucket water. The rust looks just like what you see in base of the machine. Could this be a rusty outer tub or just because it sat a while and I had to move it on its side? The rust on the bottom of the outer tub as seen in the last pic. Is that just where porcelin has chipped away or is that actually the tub rusting through? I don't know when the leak happened around the bleach hose but currently no water is leaking around the machine anywhere. Does everything look normal in the pic showing the transmission and base? Since this is my first attempt at fixing a machine up, where do I start? I value and respect all of you guys knowledge and know so any help you can give me would be appreciated. |
