Thread Number: 38473
Reseting hydrowave |
Post# 570585   1/22/2012 at 22:09 (4,477 days old) by supersurgilator (Indiana)   |   | |
Has anybody seen this before? Seriously, lifting the lid 6 times? CLICK HERE TO GO TO supersurgilator's LINK |
Post# 570594 , Reply# 1   1/22/2012 at 22:27 (4,477 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 570677 , Reply# 2   1/23/2012 at 09:08 (4,477 days old) by DirectDriveDave ()   |   | |
It's probably one of GE's worst machines. |
Post# 570792 , Reply# 3   1/23/2012 at 18:18 (4,476 days old) by dnastrau (Lords Valley, PA)   |   | |
It is too bad if that is the case especially since their old Filter Flo (pre '96) washers were well built machines that usually gave long service. What are the problem areas for the Hydrowave design? |
Post# 570794 , Reply# 4   1/23/2012 at 18:52 (4,476 days old) by washmeup (scottsdale)   |   | |
Post# 570800 , Reply# 5   1/23/2012 at 19:18 (4,476 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 570877 , Reply# 8   1/24/2012 at 02:56 (4,476 days old) by tolivac (greenville nc)   |   | |
the "flip the lid" 6 times to reset the mechanism?How many folks not know that and ----curb the machine.think I will stay away from these.Too much electronics-give me a transmission anyday!And yes-with these newer design machines-READ the BOOK! |
Post# 570902 , Reply# 12   1/24/2012 at 07:07 (4,476 days old) by mrb627 (Buford, GA)   |   | |
Post# 571047 , Reply# 14   1/24/2012 at 20:18 (4,475 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
GE TL washers since they went to the plastic tubs [ and now some have SS tubs ] Have had very poor durability in heavy use situations. Major weak parts of models with transmissions, transmission, main tub seal, motor clutch, brake assembly [ requires transmission replacement ].
Newer models without transmissions, Tub bearing and seals, Electronic motor, and tub assemblies that fly apart and or brake loose from aluminum mountain plate.
Both of these washer designs are nearly impossible to do major tear downs to after just a few years due to corrosion of the basket mounting nut and related parts, so they just get junked.
The new WP built belt drive washers are a much more durable design and like the DD machines will be much easier to dissemble and repair. |
Post# 571111 , Reply# 16   1/25/2012 at 00:59 (4,475 days old) by qualin (Canada)   |   | |
> Are you referring to the black and red light switches Oh, I thought that's what those were for, one being motor reset. |
Post# 571171 , Reply# 17   1/25/2012 at 10:41 (4,475 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
