Thread Number: 38674
1967 Kenmore washer 5480series Leak |
Post# 573767 , Reply# 1   2/5/2012 at 17:54 (4,463 days old) by kenmoreguy64 (Charlotte, NC)   |   | |
Hi Al -
Your machine is a 1965 model 800 series. This model had looong legs and was produced into 1968. The platform you refer to is called the baseplate. There are four or five things that could be getting the baseplate wet. First, the tub drain grommet could be leaking. So could the tub centerpost seal. The tub bleach hose could also be leaking or the fill control hose could as well. Finally, there could be a hole rusted in the tub. The first four can all be fixed. If there is a hole in the tub, that may or may not be fixable. If you want to take out the inner basket for further inspection, we will tell you how to do it. Gordon |
Post# 573802 , Reply# 2   2/5/2012 at 21:04 (4,463 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 573808 , Reply# 3   2/5/2012 at 21:29 (4,463 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Even a leaking outer tub can be fixed, it just depends how much work you want to do. The bleach hose on this machine is also the hose carries the fabric softener from the dual dispenser chambers and it connects directly to the side check valve housing. So if this is the cause of the leak it is easy to see and fix without removing the inner tub. |
Post# 573815 , Reply# 4   2/5/2012 at 21:46 (4,463 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
John, how is that? The hose feeds thru the outer tub from the inside. I've repaired a leaking bleach hose by removing the inner tub, removing the hose from the inside, cleaning it and the tub, applying sealant and reinstalling.
Do you mean just slather a bunch of sealant around the outside of it?
Kevin |
Post# 573818 , Reply# 5   2/5/2012 at 22:12 (4,463 days old) by kenmoreguy64 (Charlotte, NC)   |   | |
Kevin -
John is right. This model does not have the same sort of bleach hose that you worked on in the pics. The check valve, which is what is broken in your 63, has a port for the additives hose and thus does not have a separate bleach port. I forgot about those older valves. Andy - Yes the tub bolts could be leaking too. They often leak through holes rusted in the tub around the bolt gasket. Gordon |
Post# 573833 , Reply# 6   2/6/2012 at 00:06 (4,463 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
