Thread Number: 38847
Hold The Phone! GM/Frigidaire Parts |
Post# 576314   2/16/2012 at 11:58 (4,452 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 576326 , Reply# 1   2/16/2012 at 12:37 (4,452 days old) by BrianL (Saddle Brook, New Jersey)   |   | |
Post# 576356 , Reply# 2   2/16/2012 at 14:57 (4,452 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
WO-65 timer #5430706 |
Post# 576362 , Reply# 3   2/16/2012 at 15:15 (4,452 days old) by lebron (Minnesota)   |   | |
Post# 576364 , Reply# 4   2/16/2012 at 15:17 (4,452 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 576365 , Reply# 5   2/16/2012 at 15:19 (4,452 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 576373 , Reply# 6   2/16/2012 at 15:58 (4,452 days old) by lebron (Minnesota)   |   | |
Greg - the original timer that came with the machine lasted about 50 washloads before it started to act up. It started at the end of the cycle when the motor would cut off but the spin solenoid would stay engaged and the machine would coast to a stop. This was over a year ago so I don't remember all the other symptoms. Eventually the timer became unusable which brings us toooooooooo......
Ben - I still do appreciate what you did for me and this is by no means looking a gift horse in the mouth, but the timer never really worked right from day 1; unfortunately my "repairs" didn't help anything either and I take most of the blame for this timer not working. The first problem I encountered was that the timer only gave 30 seconds of wash before it would go into the overflow rinse. If left alone ( which I never do) it would fill for ~10 minutes, wash for 30 seconds, then start the overflow rinse. At first, I thought this was going to be the only problem so I came up with an idea to use my Unimatc ( I was desperate :D ). I decided to install a switch in the cord that supplies power to the timer motor. I would let the machine fill, manually advance the timer to only increment that gave wash, and then shut off the switch to the timer motor. The timer would then be stuck in wash, and I could then turn back on the switch when I was ready. This actually worked fairly well for about 5 loads and I didnt mind at all that I had to babysit the machine. Again this was awhile ago, so I dont remember all the symptoms, but the timer began to act up much in the same way that the original one did, and after 2-3 more loads became unusable. |
Post# 576374 , Reply# 7   2/16/2012 at 16:03 (4,452 days old) by swestoyz (Cedar Falls, IA)   |   | |
