Thread Number: 38941
easy spindrier |
Post# 577618 , Reply# 3   2/22/2012 at 11:27 (4,447 days old) by akronman (Akron/Cleveland Ohio)   |   | |
If you have the 2 faucets, then all you need is the spincan with the perforated cone inside. It's a one-piece spincan, there's no installing just the cone, you have to find one built with the spincone.
Pump---no electric switches, it's on and running the whole time the motor is running, the question is 2 fold: Is the pump pulley turning? Are the flippers/ports inside the pump open? Check the ability to turn the pump pulley by hand, AFTER LETTING IT SIT FOR AN HOUR WITH HOT WATER. A Picture would help, but you probably have 3 or 4 levers in front in a circle, all the controls. Those operate long wire pushrods, lik a lawnmower choke cable, that push and pull the ports open and closed, a common source of breakage.
If your machine is pretty darn close to the picture I have, then you need to follow those cables from the 2 grey lower levers all the way to the pump. Then you'll see the 2 flipping port stems sticking out from the pump, see if you can hand operate them a bit AFTER IT WARMS UP IN HOT WATER. These machines wash well and the spinner/rinse is great, but the pumps are intricate, tricky, and no longer made.
Posting a picture of your exact machine would help, Easy made many varieties each year. And if yours is one of the rare 2 speed models, I believe that most of the mechanics are quite different, sorry. |
Post# 577708 , Reply# 4   2/22/2012 at 20:27 (4,446 days old) by washerlover (The Big Island, Hawai’i)   |   | |
Just ran across this...I'm 4 1/2 hours away but there must be someone there that can add this to their collection? Think it may be a bit overpriced...
CLICK HERE TO GO TO washerlover's LINK on San Francisco Craigslist |
Post# 577745 , Reply# 5   2/23/2012 at 00:56 (4,446 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
A lot of Easy history has passed through these pages. Unfortunately much of it quickly becomes "archived" and ponderous to review. Things like, model features at a given time. Faucets, no faucets, filter-flo before GE "invented" it, the spray cone, when the "handle" transmission became those knobs that break off.
Also unfortunately, despite my interest in the Spindrier, my memory is very spotty so what I "knew" 6 months ago is now lost unless/until someone refreshes it. |
