Thread Number: 39047
Dryer and Drying Times |
Post# 579402 , Reply# 3   2/29/2012 at 20:12 (4,439 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Even if it's clean, it may be clogged. Detergent residue as well as leftovers from fabric softeners and dryer sheets can clog the screen. Run the screen under some warm sudsy water, and give it a scrub with an old toothbrush.
Wile at it, check the passage to see if any lint is built up behind the screen. If on a breaker, as you said, Flip the breaker all the way off and then reset. I have a friend that paid a service call because the dryer wasn't drying properly, As it happened 1/2 of the breaker had tripped, but the other half was still connected, hence only 110V was reaching the dryer. |
