Thread Number: 39083
Wringer Washers for Dummies |
Post# 579712 , Reply# 1   3/1/2012 at 22:52 (4,450 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 579773 , Reply# 2   3/2/2012 at 09:31 (4,450 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
How the lady of the house handled big washes in the "olden days" was to first sort into similar loads, light to dark. Then starting with the first light load, to the washer, to the first laundry tub for rinsing then to the second for blueing, back through the wringer and into the basket. All the while the 2nd load was washing then to the clothesline, on to the second load, rinse and repeat as many times as necessary. Many times using the same water for all the loads, which was great if you were on well water.
Post# 580030 , Reply# 5   3/3/2012 at 09:20 (4,449 days old) by polkanut (Wausau, WI )   |   | |
Spring loaded clothespins would't have been too common. More than likely the pins would be just the plain old type that you push on, and pull off. Having grown up around grandmothers that only ever had wringer machines, I would choose a Speed Queen because they were workhorses, and the brand is still made in Ripon, WI. |
Post# 580067 , Reply# 6   3/3/2012 at 14:08 (4,449 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Wringers equal about 200rpm spin speed which is pretty low on the extraction scale. Even the "slowest" spin drier or cycle of a washing machine removes more water and residue.
Keep in mind also to gain maximum extraction from wringers you have to either bring the rollers close together and or fold items in such a way to have good compression as they go through, then refold and pass again (and maybe again). This can and often does lead to creasing that no amount of tumble drying and or ironing will remove. Finally it must be said using a wringer/mangle simply is not for those whom cannot pay attention to the matter at hand. A minute of distraction can lead to bodily harm. |
Post# 580105 , Reply# 7   3/3/2012 at 17:15 (4,448 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Since one had to dust the bookcase anyway.....
Model is Hoover 0319. Only a few (about three) pages showing various parts and so forth, then a few more pages in the repair/trouble shooting section. Considering the vast coverage given to the twin tub washer (0500) and Blackstone built automatic washer one can safely conclude that buy the time this manual was published at least the Hoover 0319 wasn't a "big". Quick peep through the service portion reveals the wringer could be left or right hand mounted. The pump has an oil port and required a drop or two now and then. |
Post# 580159 , Reply# 8   3/3/2012 at 22:11 (4,448 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
The spinner not only gets about 3 times drier but it does batches where the wringer does one item at a time and breaks buttons and zippers. And fingers unless you're really paying attention. Since the Easy already has two tubs, other than the drain the sinks don't need to be used at all.
In my (glorious) twintub days I did the first rinse in the spinner then set stuff aside for an agitation second rinse. But that was Hawaii where one doesn't necessarily go through a lot of clothes and I was just washing for myself and sometimes a roommate. And I relish the process. Grandma didn't agitate rinse in her Easy. The (lower-case) laundress of 1936 would need to control the chemistry, which today pretty much comes in one box. Otherwise laundry would shortly look like an unkept bathtub. "Soap" is really messy stuff by itself. |
Post# 580160 , Reply# 9   3/3/2012 at 22:35 (4,448 days old) by norgeway (mocksville n c )   |   | |
Fold the shirt etc, over the buttons and make sure they are FLAT going thru the wringer...otherwise they will fly out like bullets!!! |
Post# 580168 , Reply# 10   3/4/2012 at 00:26 (4,448 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Happily one has several vintage laundry manuals and a few are from around the early part of the last century.
By the 1930's a housewive/domestic laundress had her pick of various semi automatic washing machines or doing the wash by hand. In the United States at least that choice would largely depend upon the financial circumstances of the household (could they afford a washing machine), and if the area/home was wired for electric power. Going with the family has electric power and a wringer type washing machine. Washday most always began the night/day before when the laundry was gathered and sorted. There would be several loads: Whites - table linen Whites - bed linen Whites/lights - clothing/undergarments Coloured items (non colourfast) Darks As items were sorted any stains would have been treated and or otherwise attended to. Whites would then be placed into tubs or the washing machine (usually tubs to keep the washer free to be filled the next day), that was filled with warm or cool water with a bit of soda. This was the soaking phase and did much to remove surface soils and muck so the washer would have less work. The addition of washing soda helped break down oils/fats on the laundry. Non-colourfast items and darks were never soaked. Nearly 99% of typical soils and stains found on laundry are water soluble. Sugar based stains will wash out in cold water and that temperature prevents the "cooking" in of protein based stains. So soaking in cold water did much to lessen the work on laundry day regardless of the wash being done by hand or machine. Next day came the washing. If by machine the thing would be filled with hot water and perhaps a water softener (phosphates, washing soda, borax, packaged water softener) in the amount whomever was doing the wash knew was required to deal with the hardness of the local water. Then soap would be added, again this could have been packaged product such as Gold Dust, Lux Flakes, Sunlight Soap, Kirkman Soap,or if out in the country homemade stuff. Washer was turned on and once the machine was filled items wrung out of the soaking tubs would be added. The usual order was to do table and bed linens first because normally such items weren't *that* dirty. The former mostly had food and beverage stains (if any) the latter would have bodily oils and secretions (use your imagination), as well as perhaps various medications administered if someone was ill (Vaseline, etc...). After the machine had done it's work and the load was clean it would be fed into the wringer and usually allowed to fall into a sink or tub filled with hot water. There it would be manually rinsed (wealthy households may have had one of those double wringer washing machine units, or two separate washers), wrung out and then either rinsed again or sent to the boiling coppers. Whilst the rinsing of one load was going on another load was placed into the washer (with more hot water and or soap added if needed), and allowed to agitate. Boiling laundry: There are two schools of thought on this. Some ladies of the house/laundress felt that *all* white and colourfast laundry should be boiled at each washing. Others felt that the washing action of "automatic" washing machines removed the need for boiling and that the process was hard on textiles. To it's credit however boiling did allow textile fibers to open up and release any remaining trapped soap/soil residue and thus give a cleaner wash. Items that weren't boiled were rinsed at least twice or three times in water hot as the hands could bear (if using a machine that point was moot), and should he wrung out between each rinse. Finally there would be one or two cool/cold rinses with the last often being a bluing rinse for whites and light colours. Finally the wash was mangled out of final rinse water, and hung out to dry. *I'm getting tired typing this, cannot imagine doing 10 much less 100 pounds of laundry this way* *LOL* After laundry was dried then came starching and ironing..... |
Post# 580170 , Reply# 11   3/4/2012 at 00:57 (4,448 days old) by qualin (Canada)   |   | |
Oh wow... Well, at least I know most of the procedure! Thanks for the contributions! |
Post# 580171 , Reply# 12   3/4/2012 at 01:04 (4,448 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Soaking period acted as a "break" in that it broke soils away from the fabrics. This meant the soap in wash water had less work to do and more important there was less acid/scum producing soils to make washing with soap difficult. This in turn allowed more than one use of wash water with perhaps using less soap.
Post# 580173 , Reply# 13   3/4/2012 at 01:11 (4,448 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Unless they were living out in the woods and or the lady of the house/laundry help was ill, there never would be 100 lbs of washing in a household in the 1930's.
For one thing even the very wealthy didn't own that much clothing on average. The lower one got down on the social scale meant fewer change of clothing. Because there was so little of it persons wore items much longer than we would consider decent today. Only those with funds for large wardrobes and or the funds to pay someone to do the washing changed clothing (including undergarments) daily if not several times. Bed linen often was changed only once a week or fortnight. Remember this was the era when many only bathed once a week (Saturday night). A large amount of linen would to me at least imply a boarding house or some sort of fully or quasi commerical establishment. In either case in most all urban areas there were plenty of "steam laundries" that would have made quick work of that washing with probably better results than doing it at home. |
Post# 581606 , Reply# 14   3/10/2012 at 18:45 (4,441 days old) by wetguymd (Maryland)   |   | |
I would be in heaven!! I love my wringers! My favorite would be a Kenmore Vista with a roto swirl agitator and the big open wringer. I would separate the 100 pounds into loads...sheets, whites, towels, light colors, dark colors, etc... Back the machine up to the sinks and fill it up with the hottest water possible. Put in about a 2 cups of "old" Tide and about a cup of bleach and put in the white sheets. These would wash for about 30 minutes. During this time I would fill both sinks with cold water and put a few drops of blueing in the first tub and some Final Touch fabric softner in the second one. After about 30 minutes I would run them thru the wringer into the first tub and then put in the whites and put the lid back on and while they washed for about 30 minutes I would rinse the sheets in the first rinse and run them thru the wringer to the second rinse with the Final Touch and then into the clothes basket. Now its time to take them out to the clothes line and hang them on the line. Spring clothes pins. No prettier sight than a nice line of bright white sheets blowing in a breeze! By the time this is done its should be time to run the whites out and repeat the process changing the rinse water as needed...usually after each load. I would wash the light colored next and then the towels... if I didn't have a lint filter going on the machine I would change the wash water before I did the dark clothes.
I use my wringer every week. I have for years. I have a Maytag that belonged to my Grandmother that I use but the reason I mention the Kenmoe here is because that is what my Mom had when I was a kid before she got a GE Filter Flow. I have such fond memories of the Kenmore running in the early morning before I went to school. To this day I follow this pattern when I wash and usually only wash once a week... although I don't hang all the clothes outside anymore... I do hang the sheets out and always the dress shirts. Sometimes in the summer I will put every thing out. Its so nice to have that fresh smell in the clothes! So 100 pounds of clothes would only be like 8 or 9 loads in the wringer and I would be a very happy camper!!! :-) |
Post# 581617 , Reply# 15   3/10/2012 at 19:49 (4,441 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 581686 , Reply# 17   3/11/2012 at 09:38 (4,441 days old) by wetguymd (Maryland)   |   | |
I agree that 30 minutes is excessive. But thats what my Grandmother did...especially with the heavily solied ones like the sheets and whites and demin. They washed while she did the rinsing and hanging and I guess that took about 30 minutes. Her machine (Maytag that I have and use today) didn't have a timer on it. Mom's Kenmore did and she would set it to the fabric she was washing and then the machine would shut off.
As for the rinsing.. yes you need to get in there and work the clothes in the water to get the soap out. Since its cold water a washing stick is not needed. |
Post# 581689 , Reply# 18   3/11/2012 at 10:04 (4,441 days old) by cehalstead (Charleston, WV)   |   | |
my wringer rinse tubs are ALWAYS filled with warm water....never cold. |
Post# 581705 , Reply# 19   3/11/2012 at 12:19 (4,441 days old) by mickeyd (Hamburg NY)   |   | |
had 5 kids, thus washing for a family of 7, easily 100 pounds plus, used her Easy Spin to fly thru the laundry. A bit more laborious in a wringer, but there is no quicker way to rip through poundage than in WR or TT operation.* Indeed, when the soil is light, you can move thru at lightening speed.
* Of course excluding commercial behemoths which can swallow up 100+ in one fell swoop |
Post# 581727 , Reply# 20   3/11/2012 at 14:35 (4,441 days old) by abcomatic (Bradford, Illinois)   |   | |
HI Mike, I have the same color etc Hoover spin washer that is in your photo here. Gary |
Post# 581728 , Reply# 21   3/11/2012 at 14:45 (4,441 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 581755 , Reply# 22   3/11/2012 at 17:12 (4,440 days old) by stan (Napa CA)   |   | |
Hi Bud.
You have picked a interesting time for your "washing fantasy" I think its worth put a few things in perspective "1936" A survey in 1936 found that just under 4% were living at a BARE survival level! Average annual income 1,600 (if you had a job) Average rent $24.00 per Mo Price for new wringer washer $59.95 plus tax! As you can see, not everyone had a washing machine, more people did not have, than did! A large percentage of people did not have indoor bathrooms, let alone Washing machines, Vacuums Cleners ect. And clothes dryers were practically unheard of! It would have required almost 3 months rent in order to buy a new washer! (no mastercard or visa cards either) There was NO "Final Touch" fabric softener. Tide detergent, or any detergents! Also, and this is just to add more perspective, no antibiotics at that time! At that time most ladies often washed their own laundry separately by had in the bathroom sink (if they had a bathroom) any hung to dry in some inconspicuous place. Even if fortunate enough to have a washing machine, never would they think of putting their best dress into the machine! let alone their lingerie. A machine did not eliminate hand washing. In 1936, the first Washateria was opened in Fort Worth TX We all should be very thankful, and appreciate our mothers, grandmothers for surviving this, and that they didn't kill us so they wouldn't have more laundry to do LOL |
Post# 581860 , Reply# 25   3/12/2012 at 04:08 (4,440 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Has been around since the late 1800's/early 1900's.
The new "department" stores, corner grocer,butcher, shops etc all did to one extent or another. Someone went in (most always the man of the house as bread winner) and filled out a form/answered questions and a account was opened. Many husbands and those who handled household accounts actually preferred store charge accounts because of the detailed bills which showed just where money was being spent. In the film "Now Voyager" set in the 1930's; Mrs. Windale Vale, Charlotte Vale's dour and controlling mother asks her point blank to whom she charged her new wardrobe purchased in New York shops. You can find many old advertisments for major and small appliances along with other household goods sold on installmnet (X amount down and X amount per month). |
Post# 581862 , Reply# 26   3/12/2012 at 04:18 (4,440 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Prior to widespread use of even the existence of health insurance hospitals sent bills for their services. One could pay a certain amount per month or pay the entire thing at once.
As a former nursing student collection of various items related to that profession as always been a minor hobby of mine, as well as research. There are plenty of vintage hospital bills for delivery and mother/baby care showing payment plans floating around. Many children probably remember the joke told by their fathers that if he didn't pay the hospital would come and take him or her (the child) back. Given family planning (or lack there of), many parents had barely paid off one delivery before another arrived. The average bill one has seen ran from about ten dollars to <$100. |
Post# 581985 , Reply# 27   3/12/2012 at 17:18 (4,439 days old) by stan (Napa CA)   |   | |
You all may be missing the point, in 1936 (Great Depression) unemployment was at 16.9%. So $ 1,600 annually was an average thats if you had a job at all that paid an average, many men worked odd jobs where ever they could find them, and did NOT get paid an "average"
If you where a women, you might find yourself with a bigger problem, in so much as employers didn't have to pay the same wages for the same job or same kind of work! My Grandmother was a divorced women with two kids in 1936, and had to lie to her employers by telling them that she had never been married, and of course didn't have any children! Had they known, they would have looked down the end of their noses at her (a divorcee) and told her to go home, and back to her husband! Thats was just the reality of those times! Even WITH her job she would have been hard pressed to find a store that would have extened credit to a "mere" women, without a reference (a man) and if she had managed to get one, it would have been ONLY with THAT store, not to be used anywhere, like a VisaCard In the movie "Now Voyager" remember the story was about a wealthy family holding a high position in Boston in the 1940s, not the average "working" class in the mid 30s. Also many people of the time did not believe in credit, or "buying on time" as they used to say, and were frightened by owing money that they might find (in unsure times) that they couldn't pay back later. This was the time of "bread lines" and "soup kitchens" and a popular song called "Brother can you spare a dime" So back to washing machines. if you look at the statistics and polling of 1936, you will find that it was common that many households simply did not have one! They made do with what they had! A washboard and the kitchen sink or bathtub. By 1960 the polling shows that 1/3 of the households still did not have washing machines, and that those that did, almost half were still wringers that had been purchased 5 to 10 years earlier. and since they were still working " why buy another" Another % in 1960 were still buying wringer types because they could get them cheaper, or second hand, as the wringer models were less likely to break down, and could easily be refurbished. |
