Thread Number: 39101
Normal? |
Post# 579770 , Reply# 1   3/2/2012 at 09:18 (4,438 days old) by runematic (southcentral pa)   |   | |
Ok, you're Crosley is probably a Maytag Performa-based washer. They do have a strong pump on them. Most of the connections we do are to standpipes and not sinks. How tall is the pipe before the trap? Is there a trap? How big of a diameter of standpipe is it? Where does the standpipe go to? It is more likely a plumbing issue than a washer issue. There also may be a build-up of lint and gak in your pipes. Anyway, I hope this helps somewhat. |
Post# 582241 , Reply# 2   3/13/2012 at 21:18 (4,426 days old) by badgerdx ()   |   | |
Why does it pump out so strongly only on the final rinse, and not when pumping out the wash cycle? That's what seems bizarre. I have no problem when it pumps out the wash cycle, only the rinse. |
Post# 582263 , Reply# 3   3/13/2012 at 22:47 (4,426 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
The only drain backup I have ever experienced with an automatic washer was in a very old house. A half gallon of bleach allowed to stand in the drain pipe overnight fixed it. Evidently the drain had become restricted by deposits the bleach could attack.
If you look, $5 liquid drain cleaner is the same thing as $1 storebrand bleach, sodium hypochlorite. There may be a deeper plumbing problem to explain why the first drain does not cause the problem but the second drain does. |
Post# 582539 , Reply# 5   3/15/2012 at 03:10 (4,425 days old) by pdub (Portland, Oregon)   |   | |
Post# 582543 , Reply# 7   3/15/2012 at 04:40 (4,425 days old) by tolivac (greenville nc)   |   | |
Where do you get the "Drain Blaster" tool?would like to try one instead of a $400 power snake from Lowes or ??? for a plumber. |
