Thread Number: 39520
Beautiful 1959? Imperial 90 super wash |
Post# 585642 , Reply# 1   3/29/2012 at 02:59 (4,411 days old) by stan (Napa CA)   |   | |
Post# 585653 , Reply# 2   3/29/2012 at 06:44 (4,410 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I am assuming that your washer is a pre-1967 WP belt drive machine if it actually says RCA on its control panel, a model # is always helpful. If the motor is running and the belt is moving it is NOT a bad lid switch or timer, it could be a bad water pump or a blocked Self-cleaning lint filter, drain protector, or side check valve. If the machine has been moved make sure that the drain hose is not kinked. Good Luck let us know what you find. |
Post# 585684 , Reply# 3   3/29/2012 at 09:47 (4,410 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 585687 , Reply# 4   3/29/2012 at 10:13 (4,410 days old) by lebron (Minnesota)   |   | |
