Thread Number: 39931
beko washing machine |
Post# 591246   4/21/2012 at 16:47 (4,388 days old) by candyricky (uk)   |   | |
Post# 591255 , Reply# 1   4/21/2012 at 18:06 (4,388 days old) by Tomturbomatic (Beltsville, MD)   |   | |
How well does it extract between the water changes? Thanks |
Post# 591342 , Reply# 2   4/22/2012 at 10:36 (4,387 days old) by jmurray01 ()   |   | |
Looks great, but does it take forever to do a load like my WM5100W ? |
Post# 591368 , Reply# 3   4/22/2012 at 15:03 (4,387 days old) by splittub (Europe)   |   | |
The layout on the fascia looks a lot like that of recent Electrolux group washing machines, with the knob in the midde, the 5 + 1 buttons on the right and the vertical LEDs above the buttons. |
Post# 591576 , Reply# 4   4/23/2012 at 10:33 (4,386 days old) by HotpointFan (United Kingdom)   |   | |
Post# 591781 , Reply# 6   4/24/2012 at 10:10 (4,385 days old) by HotpointFan (United Kingdom)   |   | |
Post# 591788 , Reply# 7   4/24/2012 at 11:17 (4,385 days old) by marthalover4eve ()   |   | |
basically yes :( it is silly |
Post# 591802 , Reply# 8   4/24/2012 at 12:25 (4,385 days old) by paulc (Edinburgh, Scotland)   |   | |
As mentioned by others in previous threads there are four elements that make up efficient laundering.Chemical action, mechanical action time and heat. If one of these is reduced, at least one of the others need to be increased. On my machine 60 deg cotton is shorter than 40 deg. It kind of makes sense that Beko have lengthened the times on the cooler/cold cotton cycles.
Post# 591845 , Reply# 9   4/24/2012 at 16:11 (4,385 days old) by jmurray01 ()   |   | |
It is the opposite with the 5100, the hotter the wash the longer it takes. Pees me off to be honest. It is a reliable machine though so I'm reluctant to part with it... |
Post# 591846 , Reply# 10   4/24/2012 at 16:13 (4,385 days old) by jmurray01 ()   |   | |
Actually, correction, I think it is the colder the wash the longer it takes. Sorry, my brain is working about as fast as a Windows 95 PC just now. |
Post# 591965 , Reply# 11   4/25/2012 at 04:56 (4,384 days old) by zanussi_lover (Nottingham, UK)   |   | |
Most of the time I use the Quick Wash Button when I do a wash on Cottons/Synthetics, but after the wash has finished I rerun the Beko on Rinse again with conditioner in Because the quick wash only gives 2 rinses instead of 3. And my old Zanussi FJ1225 you used to be able to select quick and super rinse at the same time giving you a short wash with 3 rinses instead of 2.
I do use the long washes for really dirty loads, I washed my mums white bedding on the Intensive & Stain 60*c cycle as it had red hair dye on it, 2 Daz Tablets a long wash of 2.5hrs at 60 got the bedding spotless and it was very white. I do think though if you use the long wash cycles for dirty loads or stained items, then it helps, most of my clothes are light/normally soiled so I feel a long wash isn't necessary, although sometimes I do wash alot of clothes on Synthetics 40*c which takes 1hr 40 minutes, or about 55 mins on Quick Wash. |
