Thread Number: 40084
Gas or Electric Halo-of-heat |
Post# 593306   5/1/2012 at 06:18 (4,378 days old) by WaterWitch (Pomona, Calif.)   |   | |
Post# 593307 , Reply# 1   5/1/2012 at 06:25 (4,378 days old) by Easyspindry (Winston-Salem, NC)   |   | |
Personally, I've only had gas dryers. Years ago, gas was much more efficient to run but not so much so anymore. My mother had an electric HOH dryer, and it was great. Given a choice, I guess I'd stick with gas if it's available. Jerry Gay |
Post# 593308 , Reply# 2   5/1/2012 at 06:39 (4,378 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 593311 , Reply# 3   5/1/2012 at 06:53 (4,378 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 593336 , Reply# 4   5/1/2012 at 09:24 (4,378 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 593345 , Reply# 5   5/1/2012 at 09:59 (4,378 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 593358 , Reply# 6   5/1/2012 at 10:37 (4,378 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Generally speaking, I prefer gas dryers over electric dryers. That said, when it comes to the Halo-of-Heat design, I prefer the electric version. I currently own (and occasionally use) both a DE806 and a DG806. I did a near total restoration on the DG806 about a year ago and have done rudimentary service on the electric one.
Here are some observations: The entire concept of the HOH dryer seems to have been designed with the electric version in mind. The gas version is a very odd setup that really looks to be almost an afterthought by the engineers. Electric HOH dryers actually dry pretty quickly given the rather paltry 4500 watt element that is in them (compared to the 5200 to 6000 watt element in other electric dryers of that era.) The two drawbacks to the HOH electric design in my experience is that the front of the drum gets VERY hot during operation. If you overload the dryer, there is a danger of scorching if items stay pressed up against the inlet area for an extended period of time. Secondly, you need to be pretty diligent about keeping the front drum felt seal in good condition. Thousands of HOH elements have been prematurely shorted out by a stray coin, paper clip or safety pin that worked its way down into the element area and then there is a tripped breaker and a service call. Also, as the felt seal disintigrates it can break off and fall onto the heating element creating a definite fire hazard. I would never leave a HOH dryer unattended while it is drying. Now the gas version is sort of crazy complex compared to the electric version. In the gas version, the burner is crammed in perpendicular to the drum at the very front of the cabinet. The flame cone sits directly under the front of the drum just inches away from a 3" wide felt seal that circles the entire drum. Because of this situation, Maytag throttled the burner output back to only 18,000 BTUs (compared to the 22,000 to 25,000 BTUs of comparable dryers of the period). Also, the gas version of this dryer used a standing pilot light. Not only does this waste energy, but the by-products of the pilot light burning for years makes a heck of a mess out of the mechanical and electrical "guts" of the dryer. After the restoration, I only light the pilot light in mine minutes before I want to dry. I then turn the gas off immediately after I'm finished. In my personal experience the gas version of this particular design is slower than the electric. A normal load of towels takes about 50 minutes in the electric HOH. The same load in the gas HOH takes 60-65 minutes. I'll post some pics of the curious design of the gas HOH dryer. Here is the front of the dryer with the cabinet removed. See how the burner and cone sit under the front of the drum. |
Post# 593360 , Reply# 7   5/1/2012 at 10:41 (4,378 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 593362 , Reply# 8   5/1/2012 at 10:42 (4,378 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 593367 , Reply# 9   5/1/2012 at 11:26 (4,378 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 593505 , Reply# 10   5/1/2012 at 20:06 (4,377 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Basically there are few important differences in the way these two different heat sources complete the job of drying clothing, in fact most of our customers don't know weather they have a gas or an electric dryer. This is not the case with gas or electric ranges where their are major differences and advantages when comparing these two appliances. That said I would always chose a gas dryer over an electric model if your home has natural gas service for the following reasons.
Gas dryers are always better for the environment as their use causes only one third of the amount of carbon dioxide to be released into the atmosphere. And the air pollution produced by burning coal oil etc is much worst in general.
Gas dryers are almost faster at drying clothing, the only documented case where I ever saw an electric dryer was faster was when CRs tested MT HOH dryers many years ago and actually found that the gas HOH dryer took one minute longer to dry the same load. The HOH dryers in general suffered from air-flow problems as the blower drive belt had a very light tension and the lint filter was too small so they did not maintain good airflow especially if the vent system was anything but short. The 18,000 BTUs of the HOH dryers was not the problem when it came to slow drying, many other gas dryers used 18,000 BTU burners including MTs first gas dryer designs. The gas HOH dryer because of the burners placement had to have a very sensitive hi-limit safety thermostat and as a result the burner often did not stay on enough of the time especially as the machine and it seals etc aged. The electric HOH also suffered slow drying because they had to use a 170 degree safety thermostat compared to WPs 390 degree thermostat.
But the best reason to always chose a gas dryer over an electric dryer is that they are FREE to own over the long run. In most cases a gas dryer will pay for itself over a 3-10 year period of time and over a life time of use you will be thousands of dollars richer. Just think if there was an option on your next car that will make owning and operating it free over your life time, wouldn't you buy it ?. |
Post# 593597 , Reply# 11   5/2/2012 at 08:13 (4,377 days old) by DaveAmKrayoGuy (Oak Park, MI)   |   | |
Gas is cheaper & more plentiful & constant, especially in commercial & industrial use!
So, naturally, I see gas, at least in the way of dryers used in nearly every household, whereas there are countless uses of it in commercial & institutional laundries, as well as in restraunts, whether it's a pizza oven, deep fryer, food warmer (a coney island I ordered my chili dog at had an un-guarded open-flame right under a table I saw while I waited for my order) or steamer! -- Dave |
Post# 968952 , Reply# 12   11/19/2017 at 17:27 (2,349 days old) by Maytag85 (Sean A806)   |   | |
Post# 969041 , Reply# 13   11/20/2017 at 04:40 (2,349 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 969167 , Reply# 14   11/20/2017 at 22:45 (2,348 days old) by Maytag85 (Sean A806)   |   | |
Post# 969176 , Reply# 15   11/20/2017 at 23:57 (2,348 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
I still think gas is more widely used where I live--people/families with electric ranges would even have gas dryers (a friend's mother opened the WARD SIGNATURE pilot door to let me see the flame), and the rest of the appliances with the exception of a no-name electric cook top and Frigidaire French door wall oven were what made these folks Norge-Nuts! Though it was only a couple refrigerators, and a plumbed-in portable dishwasher that sat in a nook under a small "L" counter...
However, some electric range homes (including my maternal-grandparents and mine) had an electric dryer for the matter of convenience, as would at least one home with a gas range out of many, maybe to get out of the dryer having a standing pilot light that needed to be lit, or just a matter of its treatment or performance drying the clothes... Electric dryers might make sense in apartment and logic laundries, as that's where they tend to be widely used, even as expensive all that DC power, efficiency-wise can be... -- Dave |
Post# 969268 , Reply# 16   11/21/2017 at 15:20 (2,347 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1034102 , Reply# 18   6/1/2019 at 01:07 (1,791 days old) by Maytag85 (Sean A806)   |   | |
Since I do own a Maytag DG306 (a DG606 I converoto a DG306), and I will say the gas HOH dryers are somewhat of an odd setup, but at least Maytag offered a gas dryer in the late 50’s as well as WP/KM, GE, Westinghouse, and Frigidaire didn’t offer gas dryers until the 1960’s. I believe GE didn’t even offer gas dryers until the mid to late 60’s, but I may be a little off with that though.
Post# 1119360 , Reply# 20   6/5/2021 at 11:06 (1,056 days old) by Maytag85 (Sean A806)   |   | |
If you upped the BTUs to 25,000, it would ruin the felt seal that helps direct air through the burner and would be a fire hazard since the burner is that close to the drum. Here’s a photo of how close the burner is to the outer felt seal and to the front of the cabinet. It’s a Rube Goldberg setup since it has a felt seal that helps direct the air through the burner and air mixer assembly and has standing pilot ignition and I usually light the pilot on mine every time I dry a load of laundry in mine and don’t feel like going through wiring each year and having to repaint the surfaces inside the cabinet and such. One nice thing about the gas HOH dryers is there isn’t a heating element to short out and if coins do fall into the heating shroud they’ll just sit there until you disassemble the dryer for a cleaning and servicing.
Post# 1119367 , Reply# 22   6/5/2021 at 12:00 (1,056 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Many gas dryers only had 18,000 BTUs including Mts earlier design and I am sure that drilling the orifice to 25,000 BTUs would not create a problem as long as vent was clean etc.
Standing pilots were a huge waste of energy, In many cases the pilot burns up to 1/2 or more of the total gas a range or dryer will use in a year. Even though a standing pilot was a simple system the number of repairs we did on CP dryers were actually more than models with electric ignition.
Maytag was always conservative in their approach to appliance design, lower HP motors, shorter wash times and maximum dry times available, smaller capacities and generally more mediocre performance, but they also used a little less water and electricity etc.
John |
Post# 1119370 , Reply# 23   6/5/2021 at 12:13 (1,056 days old) by Maytag85 (Sean A806)   |   | |
One of these days I might look into converting my Maytag DG306 to electronic ignition but I’ll have to obtain all the parts to do the conversion. Since I haven’t been using my Maytag DG306 all that much ever since I acquired my Whirlpool Imperial Mark XII set, I might just leave everything alone for now plus I plan on putting my Whirlpools into service later this month to give my Maytags a break since there is some tweaking and adjustments I’ll need to make to them to keep them running in tip top shape.
Post# 1119377 , Reply# 25   6/5/2021 at 12:38 (1,056 days old) by Maytag85 (Sean A806)   |   | |
Post# 1119382 , Reply# 26   6/5/2021 at 12:58 (1,055 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Were all electric ignition till they brought out the HOH dryers around 1958.
MT cut cost with the change to the HOH dryers in many ways, they also were going after gas company business for sales of dryers because gas sellers preferred selling dryers with CBPs so every additional dryer sold guaranteed them a certain amount of gas burned every year whether the owner ever started using the new dryer or not.
Around 1976 California banned CBPs so that was part of the reason MT gave up on the unpopular and poor selling HOH dryers.
Post# 1119393 , Reply# 27   6/5/2021 at 14:59 (1,055 days old) by Maytag85 (Sean A806)   |   | |
I don’t think it was necessarily standing pilots were banned here in California it’s just Maytag wanted to keep up with the times and probably got feedback from customers and repair techs and decided to switch to electronic ignition since you didn’t have to worry about a standing pilot going out or having to light the pilot every time you wanted to dry something.
Post# 1119397 , Reply# 28   6/5/2021 at 15:32 (1,055 days old) by sprog (Boston)   |   | |
Rationale: natural gas (methane) combustion produces
methyl alcohol formaldehyde formic acid carbon monoxide carbon dioxide water Over time, some of these byproducts of combustion eat away at older appliances... my 2 cents.
Post# 1119402 , Reply# 29   6/5/2021 at 15:58 (1,055 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1119406 , Reply# 30   6/5/2021 at 16:27 (1,055 days old) by Maytag85 (Sean A806)   |   | |
Post# 1119517 , Reply# 32   6/6/2021 at 17:33 (1,054 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Bill, I did this once on 1959 HOH dryer by using the gas burner assembly from the next generation MT gas dryer, it is not that hard to do if you are pretty mechanical.
I still have the dryer, it is a pink machine from around 1959 ? And it needs a new home soon or I may just part it out.
We rebuilt it mechanically, new front felt seals belts etc, it might already be spoken for I will check, but it must go.
Post# 1119522 , Reply# 33   6/6/2021 at 17:50 (1,054 days old) by WMJPate (Chicago, IL)   |   | |
Do the Ricardo Montalban "rich Corinthian leather car seat"s come as part of the parting out? :) Bill |
Post# 1119526 , Reply# 34   6/6/2021 at 18:13 (1,054 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1119568 , Reply# 35   6/7/2021 at 07:38 (1,054 days old) by vacerator (Macomb, Michigan)   |   | |
Did he also do the tv adds for that car? I don't remember. I was working so many hours from 1986 through 1990. I didn't watch much tv. My company was really "on the grow" then. We were opening new and remodeling existing locations every month. |
Post# 1119604 , Reply# 36   6/7/2021 at 15:10 (1,053 days old) by WMJPate (Chicago, IL)   |   | |
No, I kinda remember the adds running during "Love Boat". Yikes, does that date me or what? I think the adds were strictly for the 1977-78 Cordoba. |
