Thread Number: 4018
Okay, we give... |
Post# 94474 , Reply# 2   11/17/2005 at 20:37 (6,734 days old) by filterflo (Chicago Area)   |   | |
sorry, I meant to type: "remove the whole agitator shaft"......... |
Post# 94477 , Reply# 3   11/17/2005 at 20:41 (6,734 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 94503 , Reply# 5   11/17/2005 at 22:50 (6,734 days old) by roto204 (Tucson, AZ)   |   | |
Good to know; thank you for the good info, Jimmy and Robert. Yes, the bolt broke off in the block, so it's going to be a big nugget of joy to work on. It may end up being scrap-food after all is told, and yes, that block has to come off. Unfortunately, we have no spare parts, so if this can't be accomplished, the machine is headed for the krusher... --Nate |
Post# 94529 , Reply# 7   11/18/2005 at 06:59 (6,734 days old) by toggleswitch (New York City, NY)   |   | |
Post# 94535 , Reply# 8   11/18/2005 at 07:18 (6,734 days old) by roto204 (Tucson, AZ)   |   | |
Puh-lease!!! Our determinations of krusher-food only come after endless bouts of tears and forehead-banging. The more I think about it, the more removing the shaft will work better, and yes, we can use a removal tool to get the broken bolt out. Thing is, the agitator shaft is seized because whatever-it-passes-through on the way to the transmission is corroded. I may have a hard time just removing the Allen bolts from the bottom and pulling up, so I was hoping to get at the part where shaft meets tub and attack it with copious amounts of WD-40. We'll see how it goes. --Nate |
Post# 94549 , Reply# 9   11/18/2005 at 09:42 (6,733 days old) by frontaloadotmy (the cool gay realm)   |   | |
Go to your local auto parts botique and get some Fabulous "B'laster" PB Penetrating Catalyst; it works better than WD |
Post# 94551 , Reply# 10   11/18/2005 at 09:55 (6,733 days old) by roto204 (Tucson, AZ)   |   | |
Post# 94557 , Reply# 12   11/18/2005 at 12:32 (6,733 days old) by roto204 (Tucson, AZ)   |   | |
Post# 94707 , Reply# 13   11/19/2005 at 07:16 (6,733 days old) by westyslantfront ()   |   | |
hi jimmy.....nate is doing all the work....but if he cannot save machine, i have a mechanic who said that he will buy machine for parts....motor, pump, etc... ross |
Post# 94730 , Reply# 14   11/19/2005 at 09:53 (6,732 days old) by filterflo (Chicago Area)   |   | |
Hi Ross, saw your original post and just thought I would offer the mechanical advice. Wasnt sure who was doing the work. Maybe the washer can be used as a donor to fix other Speed Queen washer in the future. |
Post# 94770 , Reply# 15   11/19/2005 at 17:40 (6,732 days old) by roto204 (Tucson, AZ)   |   | |
Post# 94913 , Reply# 16   11/20/2005 at 21:47 (6,731 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Nate, it sounds like you may be able to pull the top open on the washer, remove the thrust collar on the agitator shaft. Next, remove the four bolts at the bottom of the agitator shaft in the tub. You might have to work on it a bit to loosen it from the spin hub, but you can pull the tub and agitator shaft out together and then get the shaft out of the center post once it's out of the machine and you can get a little "whack action" on the end of the shaft. You be nice Toggle, these are highly technical terms ;-) |
Post# 94963 , Reply# 17   11/21/2005 at 06:49 (6,731 days old) by toggleswitch (New York City, NY)   |   | |
Post# 95606 , Reply# 19   11/25/2005 at 12:12 (6,726 days old) by toggleswitch (New York City, NY)   |   | |
