Thread Number: 40471
Need help |
Post# 598851   5/25/2012 at 07:40 (4,354 days old) by jakins (Kissimmee, Fl.)   |   | |
HI All I need your help. I have a 1947 or 48 Bendix. I found it on craigs list and had it up and running for a few months. I now needs bearings. Doing the work myself is no problem it is the parts I need any ideas on where I couls find them for such an old machine. any help would be great. the pic is before.
thanks John |
Post# 598852 , Reply# 1   5/25/2012 at 07:42 (4,354 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 598869 , Reply# 2   5/25/2012 at 09:37 (4,354 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 598871 , Reply# 3   5/25/2012 at 10:09 (4,354 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 598877 , Reply# 4   5/25/2012 at 10:54 (4,354 days old) by badgerdx ()   |   | |
Can't offer bearing help, but you did an AMAZING job restoring that machine... I'm FLABBERGASTED! |
Post# 598911 , Reply# 6   5/25/2012 at 15:41 (4,354 days old) by jakins (Kissimmee, Fl.)   |   | |
the big secret is to sand then sand then sand and when your done with that sand some more. the paint is off the shelf rustoleum appliance epoxy. The motor, rubber, hoses, porcelain, were all in nice shape. and ran very quiet for about a month after she was bolted down to the floor. The only other problem i had with the machine was the speed with the oil mix, I did not need to ask for help at the time as another member was having the same problem at the time so I followed the advice of the members and resolved that issue.
thanks John |
Post# 599505 , Reply# 7   5/28/2012 at 16:14 (4,351 days old) by jakins (Kissimmee, Fl.)   |   | |
I broke into the Bendix today to start this job. Not as bad as some of the washer projects I have seen You Guys do. The clean up of the inside of this washer will be easy. Now just have to find the bearings, there is a bearing factory in town
( Orlando ) that may help. the tub seal os fine soft and flexable. hopefully will not be to bad a job. I will post some pick of the inner tub John |
Post# 599506 , Reply# 8   5/28/2012 at 16:16 (4,351 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 599507 , Reply# 9   5/28/2012 at 16:18 (4,351 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 599508 , Reply# 10   5/28/2012 at 16:19 (4,351 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 599514 , Reply# 11   5/28/2012 at 16:41 (4,351 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 599764 , Reply# 12   5/29/2012 at 20:02 (4,350 days old) by bendixmark (Winchester Mass)   |   | |
Post# 599765 , Reply# 13   5/29/2012 at 20:04 (4,350 days old) by bendixmark (Winchester Mass)   |   | |
Post# 599766 , Reply# 14   5/29/2012 at 20:07 (4,350 days old) by bendixmark (Winchester Mass)   |   | |
Post# 600182 , Reply# 15   5/31/2012 at 21:10 (4,348 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 600183 , Reply# 16   5/31/2012 at 21:19 (4,348 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 600185 , Reply# 17   5/31/2012 at 21:23 (4,348 days old) by bendixmark (Winchester Mass)   |   | |
Hey John,where did you find a bearing and how did you remove the old one and install the new one?Naturally this was all documented for all of us to see. |
Post# 600191 , Reply# 18   5/31/2012 at 21:42 (4,348 days old) by jakins (Kissimmee, Fl.)   |   | |
