Thread Number: 40606
Kenmore Catalyst |
Post# 600728   6/3/2012 at 11:54 (4,345 days old) by dynaflow (rockingham nc)   |   | |
Post# 600732 , Reply# 1   6/3/2012 at 12:00 (4,345 days old) by DirectDriveDave ()   |   | |
Sounds like a timer or motor problem. But when you say the timer counts down then "dies" do you mean it stops at "OFF" or does it stop before that? |
Post# 600740 , Reply# 2   6/3/2012 at 12:38 (4,345 days old) by dynaflow (rockingham nc)   |   | |
Post# 600741 , Reply# 3   6/3/2012 at 12:41 (4,345 days old) by dynaflow (rockingham nc)   |   | |
Post# 600748 , Reply# 4   6/3/2012 at 13:15 (4,345 days old) by DirectDriveDave ()   |   | |
Sorry, my mistake, forgot the Catalysts were usually electronic control. If the burning smell isnt coming from the control panel then maybe I would check the motor. Does the motor hum at all? |
Post# 600750 , Reply# 5   6/3/2012 at 13:19 (4,345 days old) by dynaflow (rockingham nc)   |   | |
Post# 600756 , Reply# 7   6/3/2012 at 13:34 (4,345 days old) by coldspot66 (Plymouth, Mass)   |   | |
Also check the pump...something might be wound around the pump impeller. |
Post# 600787 , Reply# 8   6/3/2012 at 16:35 (4,345 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 600788 , Reply# 9   6/3/2012 at 16:43 (4,345 days old) by dynaflow (rockingham nc)   |   | |
Post# 600796 , Reply# 10   6/3/2012 at 17:53 (4,345 days old) by DirectDriveDave ()   |   | |
Yep, that's the capacitor, it's like a black cylinder. |
Post# 600813 , Reply# 11   6/3/2012 at 19:29 (4,345 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These were indeed troublesome washers, I don't know any customers that still have one that is still running. I dare say you are correct that Sears lost money on many of these machines. We had a lot of them come in that people had given up on that were often just 3-6 years old and we would rob the the mechanical parts to fix a tired DD washers and dump all the electrical parts.
You probably have a motor, board, touch panel or motor controller problem, check it out but I wouldn't try fixing it unless you have free spare parts. |
Post# 601601 , Reply# 14   6/6/2012 at 21:04 (4,342 days old) by dynaflow (rockingham nc)   |   | |
