Thread Number: 40874
66 Frigidaire Custom Imperial dishwasher |
Post# 604766   6/19/2012 at 14:25 (4,343 days old) by dynaflow (rockingham nc)   |   | |
Post# 604769 , Reply# 1   6/19/2012 at 14:28 (4,343 days old) by rockland1 ()   |   | |
That cutting board top will have to be removed. Look for some screws at the underside front. |
Post# 604841 , Reply# 2   6/19/2012 at 18:05 (4,343 days old) by bajaespuma (Connecticut)   |   | |
Post# 604842 , Reply# 3   6/19/2012 at 18:05 (4,343 days old) by turquoisedude (.)   |   | |
Post# 604854 , Reply# 4   6/19/2012 at 19:04 (4,343 days old) by PhilR (Quebec Canada)   |   | |
Post# 604886 , Reply# 5   6/19/2012 at 22:20 (4,343 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 605000 , Reply# 6   6/20/2012 at 10:45 (4,342 days old) by firedome (Binghamton NY & Lake Champlain VT)   |   | |
Post# 605004 , Reply# 7   6/20/2012 at 11:12 (4,342 days old) by lebron (Minnesota)   |   | |
Post# 605646 , Reply# 8   6/22/2012 at 17:19 (4,340 days old) by 1952Crestwood ()   |   | |
Looks almost exactly like my 1965 turquoise one. I've never tried to take mine apart, or even gotten a chance to use it yet, but I've heard some good things about them on here. Good catch! |
Post# 605661 , Reply# 9   6/22/2012 at 19:17 (4,340 days old) by dynaflow (rockingham nc)   |   | |
Post# 606035 , Reply# 10   6/24/2012 at 17:05 (4,338 days old) by dynaflow (rockingham nc)   |   | |
fashioned a makeshift drain hose for the DW filled her with 2 large stock pots of boiling water let it soak for a few mins plugged her in set it for light wash started to pump out pump keep running it never did stop any ideas guys about ready to scrap her, admit Im not the brightest bulb in the string but this has the best of me
Post# 606042 , Reply# 11   6/24/2012 at 17:39 (4,338 days old) by varicyclevoice (Davenport, Iowa)   |   | |
Post# 606063 , Reply# 12   6/24/2012 at 19:38 (4,338 days old) by norgeway (mocksville n c )   |   | |
Dont you DARE scrap it!! I will get down there sometime and cast the demons out of it! LOL |
Post# 606092 , Reply# 14   6/24/2012 at 21:36 (4,338 days old) by dynaflow (rockingham nc)   |   | |
Post# 606402 , Reply# 16   6/26/2012 at 11:35 (4,336 days old) by PhilR (Quebec Canada)   |   | |
Post# 606403 , Reply# 17   6/26/2012 at 11:48 (4,336 days old) by PhilR (Quebec Canada)   |   | |
Post# 606407 , Reply# 18   6/26/2012 at 12:02 (4,336 days old) by dynaflow (rockingham nc)   |   | |
Post# 606412 , Reply# 19   6/26/2012 at 12:42 (4,336 days old) by PhilR (Quebec Canada)   |   | |
Post# 608101 , Reply# 20   7/3/2012 at 23:48 (4,328 days old) by PhilR (Quebec Canada)   |   | |
If it's the same timer as in my 1969 Custom Imperial, the two tabs on the motor gear might be broken. I was able to fix mine with Loctite 495 glue but that's a temporary fix! I just ordered a new one on eBay...
But first remove yours (it's located below the dishwasher, remove the lower panels, then remove the two screws that hold the braket to the right "leg" of the dishwasher, then remove the two screws that hold the timer to the bracket (those on each side of the timer manual advance shaft) after that, remove the two screws that hold the round timer motor (not the rectangular rapid advance motor), disconnect the two motor wires on the timer plug them on a 110 volt wire to see what happens. If the gear doesn't turn, it's very likely to have the same problem as mine had and the one shown on the links above. Then follow the procedures on Davesrepair website...
I just ran mine for a complete cycle and eveything works now! |
