Thread Number: 41327
hotpoint 9534 |
Post# 610786 , Reply# 1   7/17/2012 at 16:27 (4,300 days old) by boschlover1997 ()   |   | |
carbon brushes? |
Post# 610788 , Reply# 2   7/17/2012 at 16:32 (4,300 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 610789 , Reply# 3   7/17/2012 at 16:32 (4,300 days old) by andyvivo (Essex)   |   | |
Would say the triac is open circuit, attached to the heat sink of the module. The overfilling i would say is a blocked pressure chamber |
Post# 610790 , Reply# 4   7/17/2012 at 16:45 (4,300 days old) by boschlover1997 ()   |   | |
i didnt understand this: "Would say the triac is open circuit, attached to the heat sink of the module", but thankyou for your advice on the pressure chamber, will look tomorrow |
Post# 610791 , Reply# 5   7/17/2012 at 16:51 (4,300 days old) by andyvivo (Essex)   |   | |
on the electronic pcb, there is a little 3 legged device (triac) that is either clipped or screwed to the heat sink (the metal shell) This allows the correct supply to feed / regulate the motor speed. |
Post# 610792 , Reply# 6   7/17/2012 at 16:54 (4,300 days old) by boschlover1997 ()   |   | |
ah right, so i maybe need to tighten it or something? :) |
Post# 610793 , Reply# 7   7/17/2012 at 16:57 (4,300 days old) by aegokocarat (United Kingdom)   |   | |
the over filling could be the solinoid, im not too sure but its worth checking :) Tom :) |
Post# 611436 , Reply# 9   7/21/2012 at 09:51 (4,296 days old) by boschlover1997 ()   |   | |
it turned out to be a loose wire to the motor. |
Post# 611441 , Reply# 10   7/21/2012 at 12:47 (4,296 days old) by fido ()   |   | |
Probably a tacho coil wire. What about the over-filling? |
