Thread Number: 41363
Whirpool Duet & Rinsing |
Post# 611364 , Reply# 2   7/20/2012 at 14:44 (4,297 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 611389 , Reply# 3   7/20/2012 at 19:39 (4,297 days old) by appnut (TX)   |   | |
Post# 611429 , Reply# 5   7/21/2012 at 07:45 (4,297 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
if the washer water temputure is on the cold water temputure witch i use it skips the cool down process on the normal casual cycle so if your wife set the washer to do a cold water wash for exemple it will skip the cooldown process. and has for the filling problem it might be the water hookup hose that might eather be squezze by the washer if its to close to the wall or the water hose hook ups might have kinks preventing the water from going true to the washer.
Post# 611430 , Reply# 6   7/21/2012 at 07:59 (4,297 days old) by roscoe62 (Canada)   |   | |
Hey Pierre, Tks but unfortunately it is not the situation, the hose(s) were checked and I don't wash in cold water. |
Post# 611431 , Reply# 7   7/21/2012 at 08:08 (4,297 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 611575 , Reply# 11   7/22/2012 at 13:55 (4,295 days old) by stevet (West Melbourne, FL)   |   | |
Roscoe, What model Duet do you have? My 9150 does 3 rinses automatically and I can add the extra rinse if desired. But only the delicate and silk cycle add any appreciable water during each fill and rinse. The heavy and extra white cycles don't add anything extra. |
