Thread Number: 41368
The real problem with the Westy Dryer! |
Post# 611392   7/20/2012 at 20:17 (4,297 days old) by moparwash (Pittsburgh,PA )   |   | |
After thinking it was the motor was bad..(had it rebuilt) the real culprit is the fan bearing is shot, which caused the fan belt to stick...evidence on the pulleys uggest that the belt spent most of its time slipping in one place...after lubing the fan without taking it apart, it ran for 5 min then would stick, so I took it apart and this is what is there
Post# 611393 , Reply# 1   7/20/2012 at 20:19 (4,297 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 611401 , Reply# 2   7/20/2012 at 23:19 (4,297 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 611440 , Reply# 3   7/21/2012 at 12:41 (4,296 days old) by bendixmark (Winchester Mass)   |   | |
My parents had a 1962 westinghouse that used to have this problem.I used to take it apart and lube the fan with my father. |
Post# 611490 , Reply# 4   7/21/2012 at 20:50 (4,296 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 611491 , Reply# 5   7/21/2012 at 20:56 (4,296 days old) by appnut (TX)   |   | |
Post# 611494 , Reply# 6   7/21/2012 at 21:08 (4,296 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 611507 , Reply# 7   7/21/2012 at 22:13 (4,296 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Our Westy, the fan was on the motor shaft. It needed lint removed from between inner and outer drum now and then, and one drum support assembly (roller and bearing, left side) but nothing else ever went wrong with it.
I grew up in a Westing-house but I never saw a 'program computer' Westy in real life. Didn't catch on, too far ahead of its time I spoze. |
