Thread Number: 41383
LG Turbo drum washer |
Post# 611527 , Reply# 1   7/22/2012 at 01:37 (4,296 days old) by ronhic (Canberra, Australia)   |   | |
Friends of ours in Sydney have had one for 14 years. It has been incredibly reliable only needing a pump and hose in that time, which he did himself. I'd suggest that, provided the electronics are fine, it would last and that non 'electronic' parts such as pumps etc are easy to do.
Have a look at your friends - I bet that there will be an issue with either the pump or a hose for it to leak that badly... |
Post# 611701 , Reply# 2   7/23/2012 at 06:04 (4,295 days old) by twinniefan (Sydney Australia)   |   | |
Hi Norgechef,
We have owned one of these washers for the last 5 years and it hasn't missed a beat, have been very happy with it,all the Turbodrum function means is that the pulsator turns in one direction, the drum turns the opposite way and the 3 mini wings on top of the pulsator turn around as well. I find it has a good rollover of loads, however I would advise if you get one do not put too may items with either long sleeves or long legs in one load as the load will tangle, otherwise no issues with tangling. Hope this helps you decide. Cheers. Steve. |
Post# 611742 , Reply# 4   7/23/2012 at 12:15 (4,294 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 613153 , Reply# 5   7/29/2012 at 08:47 (4,289 days old) by hooverzodiac12 (Melbourne, Australia)   |   | |
