Thread Number: 41400
Naughty DishDrawer |
Post# 612071 , Reply# 1   7/24/2012 at 16:42 (4,293 days old) by marthalover4eve ()   |   | |
im guessing it dosent dry the dishes |
Post# 612095 , Reply# 2   7/24/2012 at 18:16 (4,293 days old) by washer111 ()   |   | |
Not quite, but its an issue related. I'll give you a hint: It uses Residual Heat Drying, so it has something to do with what happens beforehand :) |
Post# 612146 , Reply# 3   7/24/2012 at 23:25 (4,292 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 612193 , Reply# 5   7/25/2012 at 08:33 (4,292 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 612343 , Reply# 7   7/25/2012 at 19:58 (4,291 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 612447 , Reply# 9   7/26/2012 at 08:55 (4,291 days old) by DADoES (TX, U.S. of A.)   |   | |
Here's a Phase 6 chart for the European market. Initial cycle times are based on a stated, expected input water temp. As you know, cycle time is extended as needed to reach the target temps. Note the behavior for Normal Eco described on this chart. Begins in the Prewash period, fills with 2.5l, washes for 12 mins or to 42°C, then moves to Main Wash without draining, fills 12 seconds additional and washes for 42 mins or to 54°C. Interesting that on Ph7 (and presumably other) models that don't run a distinct prewash, the user guide doesn't show that the prewash cup is to be filled with detergent, but neither does it state that the cup must not be filled. |
Post# 612601 , Reply# 11   7/26/2012 at 20:02 (4,290 days old) by DADoES (TX, U.S. of A.)   |   | |
My point is that there are any number of software/cycle configurations, even on units within the same phase/series but aimed at different marketing regions. Also is not unusual that F&P issues revisions without changing the model/series directly. Engineering revisions are sometimes stated as beginning at a specific production serial number. My DD603 is a Phase 3. I think the 603 series was produced longer than any other thus far. There was also a Phase 3.5 revision in the 603 series (added on-board water softener module). None of the 4+ downloaded user guides I have for 603 match the cycle configurations stated in the printed material included with my machine. Your user guide does not match what you observe the machine is doing? |
