Thread Number: 41918
My Maytags" Birthdate |
Post# 617532 , Reply# 1   8/16/2012 at 11:54 (4,271 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Are you sure it's an "O"? According to my charts, Maytag never used "O" in the dating codes (I assume because it looks too much like a zero). My guess is that it's a "Q". In that case your washer was "born" in June of 1972 and your dryer is from October of 1970.
Charts such as the one below have been posted before but I wasn't having an easy time finding one so here it is again: |
Post# 617868 , Reply# 2   8/17/2012 at 12:50 (4,270 days old) by 2packs4sure (houston)   |   | |
My A-308 washer that i bought used in 1986 and still use ends in AX. That chart blows my mind. I think there is something missing. |
Post# 617882 , Reply# 3   8/17/2012 at 13:55 (4,270 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 617883 , Reply# 4   8/17/2012 at 14:08 (4,270 days old) by 2packs4sure (houston)   |   | |
There is no X on the list for the 1966 thru 2013 . and mine is an AX. It's possible i misread it but i don't think so. A-308 907206 AX Thanks |
Post# 617910 , Reply# 6   8/17/2012 at 16:36 (4,270 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 989419 , Reply# 7   4/4/2018 at 10:52 (2,214 days old) by americana4 (Warwick, RI)   |   | |
Did Maytag use the same letter codes for dishwashers? Mine has 8 digits, followed by two letters. Seems likely, but that puts it at 97, newer than I expected. Thanks |
Post# 1121445 , Reply# 9   6/26/2021 at 07:47 (1,035 days old) by dnastrau (Lords Valley, PA)   |   | |
The "XP" in the "35177XP" serial number should be read as "1965 August". The "J108561" serial number does not seem to match the typical configuration (maybe someone else has seen this configuration?) Andrew S. |
Post# 1123088 , Reply# 13   7/12/2021 at 14:48 (1,019 days old) by Hippiedoll ( arizona )   |   | |
