Thread Number: 42295
Kitchenaid Imperial Selectra 21 wiring |
Post# 622452 , Reply# 1   9/4/2012 at 00:03 (4,252 days old) by pdub (Portland, Oregon)   |   | |
Post# 695006 , Reply# 4   8/7/2013 at 20:25 (3,914 days old) by pdub (Portland, Oregon)   |   | |
So did you get the loose wire reconnected to where it was supposed to be?
There is no code L for anything on this dishwasher. The only codes you would see would be: PF= Power Failure CA= Cancel dO= Door Open Otherwise the display shows the minutes counting down as the cycle progresses. I am hoping nothing got damaged with the control board when you were cleaning the panel as any parts for the electronic timer or computer display are no longer available. |
Post# 695195 , Reply# 6   8/8/2013 at 16:46 (3,914 days old) by pdub (Portland, Oregon)   |   | |
It's hard to know what it could be but I would see if you can find any loose wire connections inside. There should be NO wires hanging inside not connected to something.
If you find something and can't tell where it is supposed to go, take a picture and post it here and I can direct you from there. It is definitely worth fixing if it's something simple as you have a rare dishwasher model that is not often found. It will clean faster and better than almost all new dishwashers. |
Post# 695480 , Reply# 11   8/10/2013 at 00:58 (3,912 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Since there is a connector on the wires, look for another connector like it with no wires attached. |
Post# 695526 , Reply# 12   8/10/2013 at 06:38 (3,912 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 695845 , Reply# 14   8/11/2013 at 13:00 (3,911 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
....Would be to have a wonderful pasta meal, then let your wife have at it with the Selectra. To be fair, she should get to load it "her" way, with no input from anyone else.
So long as a quality detergent is used, I bet it will pass her most critical judgment. P.S.: Where in Chattanooga are you? I used to live on East Fourth, close to The Battery. I was there for a bit over two years on a job transfer. Very nice town in many ways. At the time, the Tivoli downtown used to have a classic movie matinee on Saturdays, which was huge fun; one of those showings was the only time I've ever seen 1933's Grand Hotel on the big screen. At that time, the Brass Register was open in Fountain Square, right around the corner from me; I used to dote on Sunday brunch there. |
Post# 695922 , Reply# 15   8/11/2013 at 19:00 (3,911 days old) by pdub (Portland, Oregon)   |   | |
