Thread Number: 42527
Another Commercial Grade Washer that COULD be Used in a Residence |
Post# 625725 , Reply# 1   9/17/2012 at 19:25 (4,238 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Shouldn't get persons worked up without offering *something*! *LOL*
CLICK HERE TO GO TO Launderess's LINK |
Post# 625735 , Reply# 2   9/17/2012 at 19:46 (4,238 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
These units aren't being marketed for "domestic" use but route/coin-ops/condos/multi-family and OPL situations.
Basically what you've got is a very well built (one homes) energy efficient quasi commercial washing machine meant to replace top loaders and or domestic machines like Maytag's Neptune's that are adapted for commercial use. Major claims to fame are the washer's lifespand (15,000 duty cycles minimum), and the fact it will continue washing no matter how bad oversuds conditions are, hence the triple sealed bearings one supposes. Like many coin-op/laundryette washers you get only four set wash programs (Hot, Warm, Cold, Delicate) plus two cycle modifiers (Extra Rinse and Heavy Soil), without any means of user adjustment from what one can see. |
Post# 625781 , Reply# 3   9/17/2012 at 22:40 (4,238 days old) by qualin (Canada)   |   | |
Looks like direct competition to Speed Queen's front loader offering. |
Post# 625799 , Reply# 4   9/18/2012 at 00:04 (4,238 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
I wonder how much it costs and of course how many gallons of water does it use? It it only gets the clothing just damp, what good is it? |
Post# 625802 , Reply# 5   9/18/2012 at 00:20 (4,238 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
About $1800 MSRP (found around the Internet), obviously dealers may vary.
Extraction is 1000rpms with 300 g force. Considering the size of the drum this washer shouldn't be leaving items "dripping wet". Surely does a better job of extraction than most current laundryette SQ, Wascomat and other machines. As for water use the specs say it can be adjusted in the field. One assumes therefore there is some play to give higher wash and or rinse levels. |
Post# 625807 , Reply# 6   9/18/2012 at 00:56 (4,238 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 625818 , Reply# 7   9/18/2012 at 01:33 (4,238 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Or one just isnt' understanding what a poster was saying. Cannot be $1800 for a quasi commercial washer, nope, must cannot be not at all.
Post# 625820 , Reply# 8   9/18/2012 at 01:43 (4,238 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
If one wanted to do without all the La-De-Dah of various cycle options and just wanted to get on with the thing of washing.
Mind you I would want to have one of those older Rudd water heaters that put out 180F temps directly to the machine along with a short run to keep the water from cooling off. As for stain removal you're it's probably going to be LCB unless the pre-preprogrammed cycles can be extended to accomodate |
Post# 625983 , Reply# 10   9/18/2012 at 18:37 (4,237 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 625998 , Reply# 11   9/18/2012 at 20:32 (4,237 days old) by 300C (Jonesboro, GA)   |   | |
Is the machine a bolt-down, or does it have a suspension? I juast read the pdf. The machine has a suspension system. |
Post# 626003 , Reply# 12   9/18/2012 at 20:47 (4,237 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 626041 , Reply# 14   9/19/2012 at 01:17 (4,237 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Commercial laundry equipment most always is sold via dealers whom have considerable leeway in terms of pricing. These CrossOver units are geared towards route and apartment laundries and laundromats. In such cases it's hardly likely someone is going to purchase just one machine. There are probaly also dealer and or manufacturer incentives and or discounts as well.
Post# 626047 , Reply# 15   9/19/2012 at 02:13 (4,237 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 626050 , Reply# 16   9/19/2012 at 02:46 (4,237 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Remember reading something awhile ago that most commercial/laundromat washer/extractors use an industy standard of $100-$200 per rated pound capacity.
At 22lbs using that formula would put the Crossover at $2200 on the low end and $4400 at high per machine. Yes, one assumes you get a better deal the more units are purchased and or if one is kitting out a full laundry room/laundromat. |
Post# 626108 , Reply# 17   9/19/2012 at 11:18 (4,236 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Glad to see others getting into this area, But with the SQ FL machines being rated for 25,000 loads, costing only 1,500.00, having a 3 year in home warranty and MOST important an established service network to handle the problems that will arise I see little reason to consider this machine at this time. |
Post# 626139 , Reply# 18   9/19/2012 at 14:41 (4,236 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
While nothing seems to be preventing domestic consumers from purchasing "CrossOver" washer/extractors and or dyers they are not the primary target market. These units are designed to replace top loading washing machines of all types and "appliance" type front loaders such as Maytag's Neptune and other home use washing machines that have a coin box slapped on them for use in laundromats,multi-family buildings, and so forth.
When you read various laundromat owner's opinions of soft mount machines in general most if they had a choice would go for hard mount machines. This is for various reasons but one suspects that the lack of a pump solves so many issues including suds lock and or the machine not spinning fully and or at all if overwhelmed with froth. Laundrylux goes to great lengths to promote that their machine *will* spin no matter how much froth is in the drum. Cannot comment as to what SQ or other quasi or fully commercial soft mount machines will do in the same situation. Personally like the Primus FX machines Malcolm pointed to in another thread. But they are another kettle of fish all together. |
