Thread Number: 42560
Washing machine door seals |
Post# 626250   9/20/2012 at 04:59 (4,235 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 626509 , Reply# 1   9/21/2012 at 04:34 (4,234 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 626595 , Reply# 2   9/21/2012 at 15:40 (4,234 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 626728 , Reply# 3   9/22/2012 at 05:58 (4,233 days old) by servisslimline (England, Brighton & Hove)   |   | |
Post# 627277 , Reply# 4   9/24/2012 at 10:41 (4,231 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 628302 , Reply# 5   9/29/2012 at 10:39 (4,226 days old) by ozzie908 (Lincoln UK)   |   | |
I know some Servis door seals were the same as Hoover back in the late 70's through to the 80's sadly the stickers have come off the ones that resemble Hoover/Servis so if you want to take your seal off lay it flat and measure the distance across the middle of the inside that seals around the tub and the front that seals the door if you can send me a picture of the seal you need and I will try again for you am sure there is one that may fit :)
Austin |
Post# 630861 , Reply# 6   10/11/2012 at 12:08 (4,214 days old) by HotpointFan (United Kingdom)   |   | |
Post# 630863 , Reply# 7   10/11/2012 at 12:12 (4,214 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 630869 , Reply# 8   10/11/2012 at 12:57 (4,214 days old) by aquarius8000 ()   |   | |
Hi Austin. Do you have a Hotpoint washing machine door seal to fit a WT960G? As it has a manky seal and it leaks witch is not great. Cheers, Chris |
Post# 630870 , Reply# 9   10/11/2012 at 13:03 (4,214 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 630874 , Reply# 10   10/11/2012 at 13:11 (4,214 days old) by aquarius8000 ()   |   | |
Cheers for that. If you have 2 then I would not say no as the machine indoors (WT960P) has a manky seal too. Chris |
Post# 631326 , Reply# 11   10/13/2012 at 15:46 (4,212 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 631351 , Reply# 12   10/13/2012 at 17:17 (4,212 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 631468 , Reply# 13   10/14/2012 at 07:54 (4,211 days old) by HotpointFan (United Kingdom)   |   | |
Post# 631565 , Reply# 14   10/14/2012 at 16:34 (4,211 days old) by ozzie908 (Lincoln UK)   |   | |
I will have another look in the meantime if you run a maintenance cycle with a bottle of THIN bleach from lidl for about £1 when the machine has stopped filling put the container of bleach in through the soap drawer and let it run a 90 wash that will kill off any more bacteria and fade what is leaving its mould behind. you should then be ok to use the machine as I am assuming its not leaking ?
Austin |
Post# 631795 , Reply# 15   10/15/2012 at 09:52 (4,210 days old) by HotpointFan (United Kingdom)   |   | |
