Thread Number: 42585
My shirts have an oily smell lately. |
Post# 626607   9/21/2012 at 16:29 (4,235 days old) by 2packs4sure (houston)   |   | |
My 1978 Maytag A-308 is working fine as usual but, My shirts have an oily smell lately. Maybe it's my imagination. There is no staining at all. Just a faint smell of oil. Any thoughts? |
Post# 626608 , Reply# 1   9/21/2012 at 16:32 (4,235 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 626609 , Reply# 2   9/21/2012 at 16:34 (4,235 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 626610 , Reply# 3   9/21/2012 at 16:38 (4,235 days old) by 2packs4sure (houston)   |   | |
I can't smell it in the tub and the tub is not oily at all. I've heard of old Maytags putting oil stains on clothes, maybe this smell is the very beginning. |
Post# 626611 , Reply# 4   9/21/2012 at 16:49 (4,235 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Do not know much of Maytags but my GE used to have oily smell once when I discovered a small oil leak under the agitator on the shaft, oil ran all over the inside of agitator making it black, I just lightly pushed the seal back in place with an hammer and leak stopped, and still working fine, but maytags have different drive shaft assembly so not sure where you have to check..... This post was last edited 09/21/2012 at 17:10 |
Post# 626613 , Reply# 5   9/21/2012 at 17:02 (4,235 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
My leak I think was due to machine that was putted upside down to be fixed a month before usually oil cannot reach that high, anyway GE FF have another seal just under the basket blocks, if it breaks woul be total panic as water would enter in transmission first and push oil out, also ruin tranny. |
Post# 626615 , Reply# 6   9/21/2012 at 17:06 (4,235 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 626618 , Reply# 7   9/21/2012 at 17:13 (4,235 days old) by 2packs4sure (houston)   |   | |
Thanks for all the effort. When i get home i'm gonna fill it up with hot water and let her run then sit awhile then check it. |
Post# 626620 , Reply# 8   9/21/2012 at 17:16 (4,235 days old) by 2packs4sure (houston)   |   | |
No matter what the problem is i'm going to fix it. Every newer appliance i have is junk. I bought this one used in 1986, in 2000 i did belts and hoses and that's all it's ever needed. |
Post# 626621 , Reply# 9   9/21/2012 at 17:22 (4,235 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Yes of course! Maybe it is nothing but a bad combination of detergent+softener getting an oily smell...it may happends, if i use Dash powder when using my store brand softener I get a very strange smell reminding of oil! Really!
Post# 626623 , Reply# 10   9/21/2012 at 17:25 (4,235 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 626630 , Reply# 12   9/21/2012 at 17:33 (4,235 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 626694 , Reply# 14   9/22/2012 at 00:00 (4,234 days old) by StrongEnough78 (California)   |   | |
Check all around in where the motor and transmission are. Look for any signs of leaking that may not have made it out of the casing yet. The 1976 Whirlpool we had was starting to leave stains, and when it finally died, just from sitting there until it was hauled off there was a ring of oil that formed from under the agitator. I really wish I had the know how back then, and that I knew of this website then to be able to keep it running.
Post# 626697 , Reply# 15   9/22/2012 at 00:23 (4,234 days old) by qsd-dan (West)   |   | |
If you can, try and see if the agitator will pull off. If you're lucky, it will. Check and clean around the stem and base of the agitator. Sometimes goobers will accumulate under there and build up.
Using liquid detergent, especially during consistent cold washes, will cause some build up to occur overtime. This is especially true if your cold washes are under 80F.
Buy a small case of powder detergent, crank up the water heater, and throw a good dose of powder detergent in the tub with some REALLY hot water. Try and use the powder detergent every time you wash a load of whites, with of course, hot water. Hopefully, it'll clear itself. |
Post# 626949 , Reply# 17   9/22/2012 at 22:12 (4,234 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 626951 , Reply# 18   9/22/2012 at 22:14 (4,234 days old) by qsd-dan (West)   |   | |
Post# 626953 , Reply# 19   9/22/2012 at 22:16 (4,234 days old) by StrongEnough78 (California)   |   | |
