Thread Number: 42594
Schweet Little Westinghouse Dryer |
Post# 626747   9/22/2012 at 08:36 (4,234 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
If this wasn't 220v only be all over it!
CLICK HERE TO GO TO Launderess's LINK on Pittsburgh Craigslist |
Post# 626787 , Reply# 1   9/22/2012 at 12:20 (4,234 days old) by appnut (TX)   |   | |
Post# 626877 , Reply# 2   9/22/2012 at 18:08 (4,234 days old) by Tomturbomatic (Beltsville, MD)   |   | |
It's also made to run on 110. You use the low heat setting and the timer goes to over 2 hours. |
Post# 626886 , Reply# 3   9/22/2012 at 19:08 (4,233 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 626928 , Reply# 4   9/22/2012 at 21:31 (4,233 days old) by Tomturbomatic (Beltsville, MD)   |   | |
A 110 volt heating capacity is limited by the 15 A circuit to about the same heating capacity as your WP. |
Post# 626956 , Reply# 5   9/22/2012 at 22:26 (4,233 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
From the 1950's or 1060's.
According to my copy of "Tech Talk Digest" for Frigidare automatic electric dryers of the period the 120v units ran at 1600 or later 1100 watts. Plugged into a 20amp circut things should be fine, a bit warm and moist during the summer months, but we all have to make sacrifices. *LOL* |
Post# 627096 , Reply# 6   9/23/2012 at 16:12 (4,233 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Are you sure that's not 1600 watts for the full load and not the wattage of the heater? |
Post# 627104 , Reply# 7   9/23/2012 at 17:11 (4,233 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 627105 , Reply# 8   9/23/2012 at 17:12 (4,233 days old) by Iowegian ()   |   | |
@Tomturbomatic: I had the same question. If I had to guess, I'd say the motor would draw at least 250 Watts running, more on startup. |
Post# 627107 , Reply# 9   9/23/2012 at 17:15 (4,233 days old) by Iowegian ()   |   | |
@Launderess: That's right at 14 A just for the heating element. Doesn't leave much for the motor turning the drum...or the timer motor (which wouldn't use much, but cutting things that close...). |
Post# 627110 , Reply# 10   9/23/2012 at 17:19 (4,233 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Came into USA code, but have a sneaking hunch up until the 1970's or mid 1960's it wasn't a huge issue.
Have seen plenty of appliances such as vintage ironers that pulled >1500 watts for the heater which today would be sitting very near the window's edge for a 15amp circut. Of course some ironers and other appliances got around this by using gas for heating but as they were unvented that is a huge no-no today. |
